Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Opens and closes 4 or 5 times then sticks,does it overheat?
    President:
  • 3,197 Answers
Yes the motor has a thermal overload to protect it if it is run too much.
Posted on Jul 31, 2009
If thermostat is stuck open will it make your engine cooling fan run constantly?
im assuming your speaking of the engines internal thermostat ? if this sticks open (not likely) then temp gauge on car will never reach operation temp and stay low on scale ( entire purpose of thermostat in first place) now if your coolant fan switch sticks closed (very likely) then your fan will run constantly and only shut off with the key
also another condition that makes them run more often is that engine temp gauge is over normal (showing) and this is an indicator that cooling system has a problem and needs service
Sep 29, 2016 | 1993 Geo Prizm
How do you know when your thermostat goes bad on a 96 gmc suburban
Generally it sticks open and the engine does not warm up, or it sticks closed and the engine overheats. It can also stick in between.
Jan 30, 2014 | Cars & Trucks
How to tell if your thermostat is sticking in a 1999 chrysler cirrus lxi
If it is sticking open your vehicle temp gauge will be low. If it is stuck closed your car will overheat
Aug 05, 2013 | 2000 Chrysler Cirrus
How can you tell if your thermostat needs to be replaced or is bad?
The engine either runs cold (sticking open) or it overheats (sticking closed). If it is overheating there are allot of reasons besides the T-stat.
Jun 27, 2012 | 1991 Toyota Camry
Thermostat staying to cold not goin up to half way then dropin back down 'somtimes just stays at bottom
  • Sounds like your thermostat is stuck OPEN. Most the time a thermostat sticks closed and makes the vehicle overheat from lack of circulation. A thermostat can stick open also and you won't get any significant heat in the vehicle from over circulation. Might want to replace the thermostat.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Ford Focus Cars & Trucks
Car engine temparature always show high,last two weeks temp is normal,some times come to high.i found water very hot in radiator,
Sounds like you need to replace thermostat. Thermostats open and close accordingly to engine temps. When reading goes hi usually indicates thermostat is sticking open, recirculating hot coolant. Now you mentioned it's been reading normal which makes me think this thermostat is not working consistent. So I'd change it now before it overheats and causes alot of damage. Regarding hot water in radiator, after running any time it's going to be hot, normal engine temp is around 195 degrees.
Feb 21, 2011 | Gaskets for Ford Laser
My 2005 element engine overheats at idle
Check fan for operation.
Please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines and let me know if you have questions.
Sep 21, 2010 | Honda Element Cars & Trucks
My electric sun roof is open 3-4 inches and will not open or shut although increases to open a little each time i use car
plastic lining on runners tend to crack and lift causing roof to stick. can remove plastic but roof will rattle when closed. to close manually, open small cover on roof lining in front of sunroof and crank roof closed with an3mm allen key.
May 12, 2010 | 1994 Audi 100
Power door locks sticking
remove panel and to get at solenoid...electric door openers are simply a plunger thatpulls back ,same as your solenoid on the starter,these can get rusted or dry causing poor working order...spray with wd 40 and operate several times before closing
Oct 31, 2008 | 2005 Chrysler 300
Lift master 1265lm 1993
check and see if a spring is broke on either side above the door in the middle. (big springs) that's my problem.
Aug 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
102 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
