Question about Drills
I have a Rockwell 616 Rotary Hammer. Where Can I
I have a Rockwell 616 Rotary Hammer. Where Can I get bits and a manual for it?
  • 123 Answers
The manual I do not know but the Rockwell 616 uses a 9/16" Hex Shank. You can got www.icscuttingtools.com for a list of available bits. The bits are commonly known as Skil 728 Hex Shank. You may be able to find some locally where you are. I hope this helps. Let me know.
Thx
Posted on Aug 01, 2009
Drill bit stuck in rotary hammer drill
Remove the chuck and try and release the bit.
Aug 11, 2016 | Rotary Drills
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
Makita HR4041C rotary hammer drill
There is no tension to adjust on the Makita HR4041C rotary hammer drill. If you are not getting the hammer action you think you should be it's possible the o-rings on the piston are damaged or not lubricated or the striker is stuck or not lubricated enough to work properly. If you're having problems with the bit turning, there are several gears that turn the bit that could be slipping or are stripped. If you need a manual or brakedown of the tool, one is available on www.makitatools.com. The insides of rotary hammers are fairly complicated so be carefull of what goes where if you decide to take the tool apart to check for internal problems.
Aug 26, 2012 | Makita HR4041C 1-9/16" Spline Hammer
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
How do u fit a drill bit into a rotary hammer drill model number fmtc850rhd
Pull back on the chuck and then turn the bit til it drops in place, release the chuck and it will hold the bit...
heatman101
Jun 08, 2010 | Rotary Drills
Bosch - Rotary Hammer Model 11232EVS
This site does not have the manual for the exact model number you are seeking but several that are similar and may be helpful:
http://powertool.manualsonline.com/ex/thread/view/idThread/76898
Sep 03, 2009 | Tools & Hardware - Others
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Hammer drills types
Two drive systems are available on both the hammer drill and the rotary hammer models: 1. SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. 2. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Drive systems Question
SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Makita Rotary Hammer 450 Rpm, 2500 Bpm,...
Drills Logo
394 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
