Cars & Trucks Logo
Door locking 4 times after reaching 15 miles an hour every time on a 07 santafe
4answers
Ok 05 ford explorer crank but won't start. had a mobile mechanic to checked and he said that it is the key because the chip is faulty
The chip in the key is part of the anti-theft system and immobilizer. Did the vehicle start after the fuel pump was changed? It is normal to disconnect the battery when removing fuel pump, and after a battery disconnect, the anti-theft system need to be reset.
  1. Insert the key into the driver's side door lock.
  2. Turn the key once, but not all the way to unlock the door. Leave the key in this position for 40-60 seconds. ...
  3. Do this again, but turn the key in the opposite direction.
  4. Remove the key from the door, get into your Ford, and start the engine. The system should be reset.
How to Reset the Anti-Theft System on Your Ford
https://www.google.com/search?q=ford+explorer+pats+reset
A crew of highway workers paved 2/15 mile in 20 minutes. If they work at the same rate, what portion of a mile will they pave in one hour?
3 20's in one hour, so 3 times 2/15 = 6/15 mile in one hour.
6/15 is reduced to 2/5 mile, which is equal to 0.4 mile, (4 tenths of a mile).
2answers
Was at a light 1 day and my 2002 ranger 2.3L 16 valve started running ruff wen i was waiting at the stop light ,wen the light turn green the truck had no power took like 2 miles to reach 40...
you probably need a new one of these, Camshaft Position Sensor Ford Ranger 04 05 06 07 08 3.0L OE Motorcraft DU81
cam sensor. this and the crank sensor can fail at any time and put engine in limp mode.
I have a 2004 Santafe 3.5L with 107000 miles. When I reach 50MPH, I begin to hear a rattling sound in the engine as I continue to accelerate. Additionally, the vehicle seems to lose power as I accelerate....
check the front pulley ,take it off and check the keyway ,they wear out allowing the timing gear to move ,if it gets worst then the valves will hit the pistons
1helpful
2answers
I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
2answers
Automatic Door Locks when you start driving
Yes, there is a way to reprogram your car to lock the doors when the gear selector is put into Drive.
Follow this site for a complete step by step re-program of the door locks:
http://www.nialtima.com/automatic_door_locks-113.html
Door locks
Need a tech 2 scan tool to turn it off
Remoye keyless entry
Try spraying a penetrating spray (WD-40 or similar) into key holes on door, and up into latch area. You may have to do it numerous times before things will loosen up. You may need to remove the door panel, to ensure that you've loosened up all the pivot spots on the linkages but I would certainly make sure the linkages going to the locks are all moving freely before I change a power lock motor. Sometimes spraying the lube, and assisting the motor by manually lifting/pushing down button at same time as flipping the switch, will aid in loosening it too.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
