Question about Casablanca Fan 4944D Concentra Antique Brass Ceiling
We are installing a lighting fixture on our Casablanca 4944D Concentra. We can get current across the various wires, but can not get the light to turn on. The colors of the wires are blue, black, red, white, pink, yellow and gray. Which two should we connect to the light? The only combinatio whree we can get a flow of current is white/red. However, when we attach these wires to the lights, the lights do not turn on. (We have the switch on and the pull chain pulled into the open position.) When we test the light by inserting the white and black wires from the light fixture directly into a wall socket, the light does turn on.
  • Jeremy Spatrisano May 11, 2010
    Is this being installed in a residential home or a commercial building? Also, is there a wireless remote kit being used for this fan to control the fan speeds and the light?
    President:
  • 704 Answers
On ceiling fans, the blue wire is designated for the accessory light kit. If you are using the Casablanca kit, it should be wired with a matching plug that just, well, plugs into the fan.
If you are adding another brand of light kit, you only need to connect the blue wire (hot/common) to the black wire of the light being attached, and the white (neutral) to the white wire of the light being attached.
Your fan will not have a pull chain/switch for the light attachment, as that is normally supplied pre-wired and installed in the light accessory.
If in doubt about about the wiring, contact Casablanca for a manual showing what light kits are acceptable for adding onto your particular fan model.
Also, please turn off the power before connecting the light kit to the fan.
Hope that helps and best regards!
Posted on Jul 31, 2009
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged jtobias1020@gmail.com
Mar 26, 2017 | Dryers
I have a Casablanca slumber three delta ii that I want to get a light fixture to fit. Can I use a Hunter, or are there certain ones I need to use?
You have to use the bottom plate to attach the light kit to so whatever you get ,you have to be able to screw the two screws back on the fan. I have some older Casablanca light kits that will work without the bottom cap. fanman9952@aol.com
May 13, 2015 | Casablanca Fan Dryers
Just installed a light kit on a Casablanca fan, light does not turn on
Check to make sure your light wire(blue) coming out the top of the fan is connected to a hot wire from the house.
Aug 17, 2013 | Hunter Sontera 52" Ceiling Fan with...
I have a victorian casablanca fan serial # JU13396 - 20041. A couple days ago the light fixture assembly fell off the fan and crashed to the floor. Evidently there is a type of clip that fits under the...
this clips are common for most of the ceiling fans with light fixtures.You will get this clip from local ceiling fan repair shop or from radioshack, homedepot or from walmart store.There is exactly not a part number but this pins are called ceiling fan clips. -------- if incase you dont get required clip or any substitute clip for fixing.Then you can get it from dealer.Click this link below to directly contact dealer:--- http://www.casablanca-ceilingfan.com/customerservice.html ----------- Also there is one more part site for casablanca fan parts:--- http://www.fanmanlighting.com/shop/pc/viewCategories.asp?pageStyle=h&ProdSort=19&page=1&idCategory=42 ------------ This should help.Thanks.Helpmech.
Jul 12, 2011 | Vacuums
Wired up this fan - blue and black together to the black wire, white to the white and green to the ground. The black should run the fan, the blue the light. When I turn on the fan without the light...
You really should have an electrician look at it however make sure the lamps are not installed when you are connecting the lamp sockets and also check the voltage across the two leads you are connecting the lights to. Should only be 120 volts. There could be another issue that you are over-looking and that is why I think you should have a licensed pro come and take a look.
May 23, 2017 | Broan-NuTone N-763RLN Combination Light...
I have a new chandelier with 9 12 volt halogen bulbs. I want to install an electronic dimmer switch for it. When purchasing the dimmer switch there are 4 wires included: ground, black, white and neutral....
First you must have a neutral wire in the switch box for this dimmer to work. A neutral wire (white) is a current carrying conductor. A ground wire is an equipment ground and does not normally carry current. You should never connect a device that requires a neutral to a grounding conductor.
The neutral wouldn't have to come from the light fixture as long as it's on the same circuit. Another note is to check your light fixture, and be sure dimming is ok. Another choice you could have is to install a remote dimming device. You would mount this in the fixture canopy, and then use a remote dimmer.
Aug 03, 2010 | Electrical Supplies
What is the wiring set up for the pilot to be on when light fixture is on and off when the fixture is off. it is currently wired as a night light and is on all the time
If the wiring for the night light is internal then you can not change it...
If the wire is external then all you need to do is move the hot (black) wire that feeds the light from the black feed wire to the black wire that goes to your fixture so that it is now switched....
Heatman101
Mar 03, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
My casablanca fan/light wall switch only works
No . have this checked by a licensed professional it is more than likely bad switchs in the fixture but you can never be to careful with electricity
Aug 23, 2009 | Dryers
Installaion manual for ceiling fan
there was no manual for my Aloha Breeze 42" ceiling fan with light fixture model number is 49001
Dec 03, 2008 | Aloha Housewares (93645) Ceiling Fan
Casablanca Fan 4944D Concentra Antique Brass Ceiling Logo
249 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
