SOURCE: Lens error
The most common cause of this issue on the L3 is an impact which dislodges the focus element in the very front of the lens. The metal platform that the focus system is mounted to is attached with 1 screw and is able to flex slightly under stress. When impacted it flexes and allows the focus drive to become misaligned. The lens still technically works but the camera senses that the focus is jammed and leaves the lens extended so no components will be damaged by retracting. This repair costs $145 at my shop, not an economical repair for this camera. Some parts of the focus element are accessable from the front of the lens. You can remove the metal cover (it is glued down). Generally you will not be able to re-install the lens barrier, but it can be removed without harm to the camera. When you remove the plastic plate which carries the lens barrier you will see a small metal gear, this is the base of the focus drive.
SOURCE: lens error message on nikon
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
SOURCE: Lens Cover Error-Lens Cover will not open
You may have dust or some liquid blocking the cap from opening. Take a q t tip and clean cap. Use the q t tip to try to jar cap loose.
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
