Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
LCD Display When I release the shutter, the access lamp(red light) comes on, the pix is not displayed on the lcd monitor and the camera shuts off. Battery is charged. Any ideas? Terry
  • Anonymous Nov 25, 2007
    I have the same problem. I sent it to Precision Camera for waranty service but in just a couple of weeks it started doing it again.
  • Anonymous Feb 28, 2008
    I do have exactly the same problem. Too bad, I LOVE my camera....and I'm not about to buy a Sony one...hate them....a solution anyone?
I was cleaning my CCD and damaged the shutter. Same problem. Click to take a picture and the camera locks up and powers off. Turn the camera back on and the shutter releases and the camera resets and powers on. $281 service call later and Precision fixed it quickly. Replaced the shutter. They warranty their work for 6 months. Priced way too high, but nobody would touch it. As soon as I told other repair services how I messed it up, they turned me down. I had to much money invested in the camera to toss it in the closet.
Posted on Mar 01, 2008
Why is image not displaying on LCD monitor?
Need more info. Does the menu display? Then LCD probably good. If the menu does not display, then LCD (or its driver circuitry) is probably bad. Not display after taking a photo? Or not display when you push the arrow button to turn on display. Check to make sure card is in camera. Set menu to factory default to make sure some setting in the custom functions isn't turning off the LCD. Also check the brightness level.
Jun 05, 2014 | Canon EOS 600D Rebel T3i Digital Camera
The screen on my toshiba satellite a135-s2386 has a red hue for the second that it remains on during start up. It will display fine on an external monitor. If an external monitor is not connected, and you...
This sounds like a problem with the back light. The back light is generally a small cool fluorescent light. The problem could be with either the fluorescent light or the inverter board that supplies the voltage to run the lamp. If you are able to disassemble it yourself you can usually buy an inverter and lamp online. This requires a good amount of dis-assembly and expertise but costs less. At a higher price but less expertise is a complete lcd display including frame and covers. This basically just requires removal of the top cover of the laptop to access the screws that hold the display on and access to the cables.
Best of luck, Jim
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
My camera wont turn on. The battery is freshly charged, it is installed properly and the battery compartment door is shut correctly. At one point the flash would come up, but no display on the lcd and the...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Display light not available
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 21, 2009 | Compaq Presario Notebook
Monitor flickers or 1/3 turns black, have tried wiggling cable, and moving/tapping monitor, sometime it works great, other times i fight this every few min. Doesn't matter if i turn computer all the way...
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
My screen light flickers and sometimes just shuts off. i think it might be a lose wire but i dont know... anyone got an idea to fix it
You could have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 07, 2009 | Acer Aspire 5100 Notebook
Nothing appears on the display.
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 07, 2009 | HP Pavilion ze2000 Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
LCD monitor does not light up, and consequently, does not display any image (as some other digital cameras do) during the aiming and focusing processes - sort of prescanning the image - before the shutter...
to my knowledge digital slrs aren't supposed to show you the image on the screen before you shoot because the battery would get used up too quickly this is what the viewfinder is for and the lcd is purely there to tell you info on what the settings are and to view your pics after shooting, I have the 400d and its the same for that.Hope this helps
Sep 23, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Problems whit Samsung VP-D351 Visor and LCD in mode normal blur but in mode NITE PIX OK...? Some body knows..about this...is CCD Sensor...when repairthis....please
samsung vp-d351. lcd screen was bright white at first then suddenly went off (no picture). sound and everything else ok. can anybody help?
Aug 21, 2006 | Samsung Compact MiniDV Digital Camcorder
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
119 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
