Question about HP LaserJet 3330 All-In-One Printer
MISPICK ERROR MESSAGE- CANNOT PRINT. - HP LaserJet 3330 All-In-One Printer
    Habit-Forming:
  • 57 Answers
It sounds like your pick up rollers need to be either cleaned or replaced. If the problem is happening at the top where you feed paper to be scanned, you can lift up that top cover to expose the pick up rollers. Just rotate the rollers backwards carefully and clean with alcohol and q-tip, if you have something like goo gone that would be perfect.
If the problem is happening at the bottom in the tray, open the door like you're about to replace the toner cartridge and remove it. There will be a little roller down in there, It's simple to take out the roller, but if you're not comfortable with taking it out, you can just clean it like the above rollers.
Posted on Jul 31, 2009
3 Suggested Answers
  • 1149 Answers
SOURCE: Printer error as stated
Hi:
I own a HP Laserjet 3330, and usually all that it takes to fix this problem is cleaning off the paper pick up roller with a damp cloth.
It is having trouble picking up the paper sheets, and you will get the error time after time. It seems that the recycled paper is worse than others. Remember to use a cloth dampened with only water, as other cleaners will dry out the pick up roller
Posted on Oct 26, 2009
  • 43 Answers
SOURCE: problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Posted on Mar 18, 2010
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Printer mispick message
Your printer probably needs to have the paper pickup roller replaced.
You might try to clean the roller with a slightly damp lint free cloth.
Pull out the toner cartridge and look down you will see the roller sitting there.
Gently wipe it down, reinstall the toner and try printing again.
Mar 29, 2011 | HP LaserJet 3330 All-In-One Printer
"printer mispick enter to resume"is
replace pick up rollers and or the whole pick up assembly
Dec 25, 2010 | HP LaserJet 3330 All-In-One Printer
Problems with hp laserjet 3330
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
Printer mispick
Hi ,
The print engine has failed to pick up a piece of media.There is a paper jam in the printer's paper path. Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
Printer error as stated "Printer Mispick [Enter] to resume." There was a mispick but that was corrected; however the error message is constant.
Hi:
Oct 26, 2009 | HP LaserJet 3330 All-In-One Printer
Problem with HP LaserJet 3330
hi,
try to clean the pick rollers with cotton w/ alcohol.if it doesn't work maybe your separation pad is worn out and need to replace it..
Oct 30, 2008 | HP LaserJet 3330 All-In-One Printer
Recurring error
This answer was almost exactly correct:
>hey guys, for the "printer mispick" problem, try to remove the >toner and look IF there's any paper jam inside,because this >solved my problem,..
>=open toner door
>=remove the toner
>=look carefully IF there's any paper stuck between roller
>=CAUTION - carefully and gently remove the paper if so, as it >will be a nightmare if half tear off and the half end will be more >difficult to remove,...
The only thing I did differently, that worked like a charm, was to =open the door on the other side of the machine, and
=swing down the two green levers (one on each side); this released the roller tension and removal of the paper was easy.
=Once the paper has been gently removed, put back up the two green levers, and
=close everything up, re-installing the toner cartridge as you do.
Nov 16, 2007 | HP LaserJet 3330 All-In-One Printer
HP 3300
This procedure is described relating to a different error, but it resets and clears everything and would be worth a try http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=66359&prodTypeId=18972&prodSeriesId=66359&objectID=bpl10206 hp says for your specific error: "Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge." here is the complete guide to all the above http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=66359&prodTypeId=18972&prodSeriesId=66359&objectID=bpl11283 ask again if you need more Hope this helps :)
Mar 08, 2007 | HP LaserJet 3300mfp All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
219 people viewed this question
Seeker5211
Seeker5211
