Question about GE JES738 Microwave Oven
New microwave problem
We just purchased a new microwave and the interior light does not turn on when the microwave is heating.
  • GE Master
  • 9,098 Answers
If it is new and under warranty, I would refer you to GE so they can fix it free. See the phone number in your owner's manual or at http://www.myapstore.com/Omega/Dispatcher?REQUEST=CONTACTUS
If it's not under warranty, below is info that should help you.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
For GE & Hotpoint models see http://tinyurl.com/gv383
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Posted on Nov 25, 2007
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Micreowave does not heat items. Turntable, fan, and interior lights all work. Sound while running changes after about 3-5 seconds.
The magnetron has more than likely failed, "heats food" but also! the high voltage capacitor and diode can be a source of trouble, chances are repairs will exceed the cost of a new microwave oven.
Mar 26, 2011 | GE JVM1660 Microwave Oven
We have a Sunbeam Microwave Model #SGB901, purchased less than a year ago, and it stopped working yesterday. The interior light goes on, the power buttons work, but it does not heat anything. Can you...
Could be an internal Thermal fuse or cut out reset if one is at back of casing, More seriously could be the Magnatron in which case renew machine....
Feb 19, 2011 | Microwave Ovens
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 21, 2010 | KitchenAid Microwave Convection Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
Model #GLEB27M9FBB. Microwave interior light goes
Sounds like you Magnetron or PSU has failed, or perhaps it is just a sensor.
DO NOT try to repair this yourself.
These items MUST be repaird by an authorised person. They are leathal!
Take it to a reputable repair shop and get a diagnosis.. more often than not, though, it is cheaper to simply buy a new one. Oh get a warrenty too.
Jan 18, 2010 | Microwave Ovens
Microwave not heating
You need to replace the whole door latch with an original part.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Mar 18, 2009 | GE Advantium SCA1001SS Convection /...
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JES738 Microwave Oven Logo
99 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
