Question about Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JGR8850 Gas Oven doesn't hit the right temperature
Had a turkey in there for over 6 hours and still wasn't done and it wasn't a big one. How to a calibrate the oven temp? Stove was purchase in late 90's so need to keep that in mind but really not looking to replace it. Also, the stove top burners will let the gas got but no spark (even though it is clicking.) Advice from previous repair guy was to use a BBQ lighter. Now have another ring going the same way. Any help would be appreciated.
Anita
  • Jenn-Air Master
  • 2,523 Answers
This is the oven thermosat of the flame failure device not working , you could be looking at buying new as this wiil not be cheap fix ..............
Posted on May 25, 2010
The oven does not reach the temp setting
it seems to be very expensive shop arround there are alot of con men out there and he seems to be one a control pannel for that oven $105 and easy to fix no time at all $195 to fit 20 mins work at most 30mins
Nov 25, 2011 | Jenn-Air JGR8850 Gas Kitchen Range
It takes over an hour to preheat my gas stove
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 27, 2011 | Jenn-Air JGR8850 Gas Kitchen Range
Oven does not heat up Broiler works but takes a while to ignite. Range top burners work
heatman101
Sep 29, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Oven getting up to temperature very slowly, sometimes not at all it seems. lower igniter comes on right away but gas doesn't turn on sometimes for up to 15 minutes or more
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Oven gas keeps kicking on and off like it's pulsating and can smell gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 17, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
I have a jenn-air that the exhaust fan started running on its own and will not shut off.
you mean the convection fan don't you, the one inside the oven.if it's coming on by it'self you need a new control/clock you will need the complete model # to make sure you are getting the right one about $200.00 retail price
Dec 09, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
What is an F9 error and how do I get my oven door open
We solved this by holding the light/door switch in, hit the clean button, then press stop/clear for 3 seconds.
Dec 25, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn air oven analog clock
If it's an older oven, forget about getting a new clock. Instead, have it removed (or do it yourself, mark wires and of course discontinue using oven) and try your local parts guy to see if he can send it away to have it rebiult. Best case scenario. Either that or have a technician "bypass" it for you.
Jan 01, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JGR8850 Gas Kitchen Range Logo
182 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
