Question about Garden
What oil do i put in  is it a mixture of gas and oil  regular car engine oil or special oil for mowers?
    Scholar:
  • 173 Answers
If it's a 'four stroke/cycle' engine, then 10/40 or 15/40 oil, (the type you would put in your car)
is perfectly fine.
On the other hand, if it's a 2 stroke motor, you need to use the 'Gas Additive', which, simply put,, Is, the lubrication.
Normally, there are markings somewhere on, or near the fuel tank, that will indicate wether you need the 'Additive' or not.
There ya go:)
& please don't forget to rate ;))
Posted on Jul 31, 2009
Do riding moweres use regular gas or do they need a mixture
RIDING MOWERS USE REGULAR GAS.. MIXTURES ARE USED FOR SMALL ENGINES FOUND ON STRING TRIMMERS OR BLOWERS.. GAS AND OIL MIXTURES ARE USED FOR 2 CYCLE ENGINES THAT ENABLES THEM TO BE MADE SMALLER AND LIGHTER... REGULAR GAS IS USED IN A 4 CYCLE ENGINE
Aug 15, 2014 | Sears Craftsman LiftMaster Chamberlain...
Do i put an oil/gas mixture in gas tank?
the 4 stroke engine only needs petrol in its tank . if your motor has a dipstick for oil it is a four stroke ,,only two strokes requires oil and petrol mix as they have no oil sump in their design
Jun 01, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Will putting oil in the gas tank of a 2 cycle lawnmower riun the engine?
It is not good for that motor--drain and clean and expect plug may get fouled---do it the sooner the better.
Jun 15, 2012 | Briggs & Stratton Briggs Stratton...
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
What type of oil and gasoline do you nee d to run Craftsman 6.5 lawn mower?
generally all 4-cycle lawn mower engines are tuned to use regular unleaded gas ,(I personally use mid or high grade unleaded)....and for engine oil use strait 30 WT engine oil...... I often put a dash of fuel system cleaner in each gallon of lawn mower gas,it is not absolutely neccessary but seems to help moisture stay out of gas..(DO NOT USE HEET or other methenol based fuel additives for this can cause overheating or scoring of piston and cylinder...but rather use a petroleum based additive,this allows the small amounts of moisture in fuel to pass through the carbeurator without clogging filters or fuel system for smoother running)..also...if you put lawn mower up for winter it is always helpful to use a fuel stabilizer such as "STABIL" or other such products (follow directions for use) and be sure to change the crank case oil in the spring before using....this will give you much longer life from your lawn mower...
Keep air filter clean!!!..... Happy mowing!!!....so, the answer?...regular unleaded and 30wt engine oil...if you would like..they have special engine oil for 4-stroke engines at most hardware and walmarts n such...but is just expensive 30wt oil... Enjoy your day,Todd
Nov 23, 2010 | Garden
I have a 22" murray lawn mower 3.75. Can you give me the ratio of oil/gqas mixture to use ? Please advise on best type and grade of oil to use.
my 22" murry has a four cycle engine. and you dont mix gas and oil for a four cycle engine. put gas in the gas tank and oil in the crank case.
Oct 16, 2010 | Garden
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My 1950 ford 8 n is slinging oil out the oil breather cap on the side of the block.It just started and its just flying out leaving a big trail of oil.Of course i shut it off.
Sounds like your rings are either stuck or broke. Check the compression, it's probably low or non existant on at least one cylinder. In either case it sounds like a tear down.
Jul 16, 2010 | Ford Tractor 8n Front Emblem
What is gas mixture for 3.5 hp engine?
do not put oil in gas just 87 octane gas their should be a small pulg or cap where you can ck. the oil.you do not mix gas and oil with that moter or it will smoke bad
Apr 20, 2009 | Mtd 22" Yard Machine Push Mower
Gas/ oil mixture
If it is a riding lawn mower it is probably not a two cycle engine so there would not be a gas oil mixture. It must be a 5 horse power or higher so it would use straight gas. I hope this will help you. donnyb60
Mar 20, 2009 | Poulan Garden
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
