SOURCE: 94 yota pickup starts and idles breifly then dies
If it's not your fuel filter plugged , or fuel pump malfunction, then it is probably your Mass air flow sensor, or your coil pack etc. You'll have to see if you have spark or fuel first. One of them is missing.
SOURCE: 91 F-150 300 six starts fine, then runs rough,
check idle air controll motor, Lightly tap it while vehical is running, If this helps, you will need to replace it, usaly 55.00 at the zone
SOURCE: i have a 94 Mustang 5.0, two problems , one my air
As far as the stalling is the tps sensor okay, check it to make sure its in spec, as far as the air bag light you will need to scan the codes and see what code is being stored in the system, its a 94 so you will need to count the flashes of the light and thats the code,also check the map sensor thats a common problem also with these, good day,
SOURCE: My 1987 Nissan maxima will not stay running. It
i think this car has a vaccum activated fuel pressure regulator could be your problem also a large vac leak would do this as well
SOURCE: truck dies when idling
HI
Description
The engine control module (ECM) learns the idle position of the throttle plate to ensure the correct idle. Anytime the throttle body is cleaned or replaced, the ECM must learn the new throttle position. The idle may be unstable or a DTC may set if the throttle position is not learned.
Conditions for Running the Throttle Learn Procedure
• DTCs P0101, P0102, P0103, P0107, P0108, P0111, P0112, P0113, P0506, and P0507 are not set.
• The engine speed is between 450-4,000 RPM.
• The manifold absolute pressure (MAP) is greater than 5 kPa.
• The mass air flow (MAF) is greater than 2 g/s.
• The ignition 1 voltage is greater than 10 volts.
Throttle Learn
Important: Do NOT perform this procedure if DTCs are set. Refer to Diagnostic Trouble Code
(DTC) List - Vehicle.
1. Start and idle the engine in PARK for 3 minutes.
2. With a scan tool, monitor desired and actual RPM.
3. The ECM will start to learn the new idle cells and Desired RPM should start to decrease.
4. Ignition OFF for 60 seconds.
5. Start and idle the engine in PARK for 3 minutes.
6. After the 3 minute run time the engine should be idling normal.
Important: During the drive cycle the check engine light may come on with idle speed DTCs. If idle speed codes are set, clear codes so the ECM can continue to learn.
* If the engine idle speed has not been learned the vehicle will need to be driven at
speeds above 70 km/h (44 mph) with several decelerations and extended idles.
7. After the drive cycle, the engine should be idling normally.
* If the engine idle speed has not been learned, turn OFF the ignition for 60 seconds
and repeat step 6.
first I would like to tell you, do this procedure only if the 5th digit of your VIN is C or K.
8. Once the engine speed has returned to normal, clear DTCs.
Good Luck
