Question about AMT Datasouth ACCEL-6350 Matrix Printer
Form feeding I just installed a amt accel 6350. When I try to form feed, the roller spins but doesn't grab the form. If I push the form, it will eventually grab, but pulls form crooked. I am trying to print forms that are 2-4 pages. I have set it for multi page. It almost seems as though there is not a big enough gap for the form to fall in before I hit form feed. Please help. Thanks, Melissa
  • 40 Answers
Try puting a piece of cardbord under the paper but tape it 3mm from the roller.
Posted on Jul 31, 2009
Amt accel carraige error
most likely your main board is done. You can attempt to clean (with IPA) the carriage bars and reoil the front bar only. Open the back and look at the main board. look on the gold heat sink for burnt drivers.
Jun 23, 2014 | AMT Datasouth ACCEL-6350 Matrix Printer
HOW DO I REALIGN MY ADP 6350 PRINTER
Not sure what you mean by "realign" but you can try under the test menu select pcalb. make sure there is not paper installed and the printer is not in direct sunlight.
Nov 14, 2013 | AMT Datasouth ACCEL-6350 Matrix Printer
Amt 6350 setup
your printer is locked up of some functions. to unlock hit alt and form feed then setup twice.
Jan 20, 2012 | AMT Datasouth ACCEL-6350 Matrix Printer
How do i adjust the head gap on my amt 6350
There are 2 ways. one is to press and hold setup button. While holding the button turn dial to adjust print density. The second is to enter the operations menu and scroll to the end which is #52. Press form align and config at then same time while scrolling further. Gap adjust is #58. The higher the number the further the gap. Caution. The other setting can adversly affet the printer. Unless youi know what you are doing, do not adjust the other settings.
Jan 11, 2012 | AMT Datasouth ACCEL-6350 Matrix Printer
HOW DO I ADJUST THE TOP OF PAGE FOR A FORM?
when the paper loads, the top of form is then set., If the printer is not setting this or the paper just feeds through when loading paper, go into the test menu, select pcalib and make sure no paper is in the printer. aslo make sure the printer is not in direct sunlight. this will reset your paper detection circut and therefore your tof "alignment"
Sep 07, 2011 | AMT Datasouth ACCEL-6350 Matrix Printer
My adp 6350 printer just went dead on me. if i power on and off the printer makes noise but the display won't come on and i can't feed paper in or print.
It may be something as simple as a connection to the control panel Give us a call if that does not work 515-440-2330
Thanks!
Jul 30, 2011 | AMT Datasouth ACCEL-6350 Matrix Printer
AMT 6350 printer. 'error' light keeps blinking with 'load paper' flashing. put paper in, press form feed, did not help
Perform "Pcalib". Under the test menu select pcalib. Insure the printer has no paper installed and is not in sunlight. This should fix it.
Jan 27, 2011 | AMT Datasouth ACCEL-6350 Matrix Printer
The printer will not feed forms. I replaced the line feed motor but that didn't fix it
platten driver on board most likely is bad. the driver the on the brass colored heatsink and is the one to the far right. With a multi meter set to ohms, check the diodes in front of the far right driver. Resistance shoud be real high on each one if on is low, replace driver. IC is a L298
Nov 04, 2010 | AMT Datasouth ACCEL-6350 Matrix Printer
AMT Datasouth ACCEL-6350 Matrix Printer Logo
393 people viewed this question
Top AMT Office Equipment & Supplies Experts
jasbo
jasbo
Are you an AMT Office Equipment and Supply Expert? Answer questions, earn points and help others
