Question about Frigidaire Dryers
The ignitor is clicking all the time, is this normal?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2009
  • Rylee Smith
    Rylee Smith Jul 31, 2009
    Hi
    Thanks for using FixYa. The solution i gave you earlier was not for your question. The clicking of ignitor is not a normal thing and you'll need to get your coil valves checked, also examine pilot for any short in the circuit.
    Please do rate the solution & revert for further assistance.
    Thanks
    Rylee
ADP CUHN45a-4 wont light
It is likely that either the igniter or the gas valve will have to be replaced
Dec 09, 2013 | Star Enerco Heat HSU45 Garage Heater 45000...
I have a Whirlpool super capacity 465 gas oven that won't stay lit. It often lights up the first time just fine but then it turns off which is normal but when it tries to relight itself the ignitor...
That sound to me like yall have some carbon buildup on the igniter. On this stove the igniter does 2 jobs. It lights the burner and verifies back to the control that Houston we has ignition. If junk is built up on that ignitor then she won't be sending verification of ignition back to the control. That white residue needs to be removed. NOTE: I don't have your model number I am going by what you describe that this stove is a Direct spark ignition model. If you have a normal ignitor it probably is weak and not drawing 3.5 amps to open the valve. Post a model number (bottom drawer frame)
More Here
Sep 08, 2011 | Ovens
Heater ignitor is clicking all the time, is this normal?
Hi
Thanks
Rylee
Jul 31, 2009 | Frigidaire Dryers
Ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
Ignitors wont shutoff
The common way to control the ignitors is a cam on the individual shafts acting on a 'normally open' switch that is depressed in the ignition position. One of these switches has failed and no longer able to return to its normally open condition.
You may be able to locate the defective one by 'exercising' each control back and forth past the ignition position to see if one of them will cause the ignitor to stop. You may have had a spill that has allowed food liquids to gum up the switch.
Feb 26, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Apr 15, 2008 | Cooktops
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Dryers Logo
150 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
