Question about Electrolux EI24BC65GS Stainless Steel Compact Refrigerator
I have an Electrolux beverage fridge error AF
I have an Electrolux beverage fridge model EI24BC65GS with an error code AF flashing. The fridge seems to be working fine, but I don't know what the code is.
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
SOURCE: electrolux wine cooler ''af'' code flashing
Believe it or not we had the same problem.... The air filter should be changed about every six months but it is just charcoal or baking soda or something like that and is not attached to any sensors. To reset the flashing light, make sure the control panel is unlocked then hold down the on/off and (-) buttons and it will reset.
Good Luck! Elisabeth
Posted on Sep 01, 2009
I was just having the same issue with my Electrolux wine refrigerator in terms of the "AF" code flashing on my panel....I tried everything from plugging the power plug , to calling Electrolux and even the repair depot didn't know how to initiate a re-set...the solution above to Elisa solved the problem......many thanks..take out of loc and press the on/off and (-) together
Paul in Edmonton , Alberta
Posted on Jul 31, 2010
SOURCE: Electrolux ERL6296XK1 Fridge Freezer has flashing
Had the same problem with an ew26ss65g50. unplug the machine and let it defrost. then plug back in after an hour or so. problem is the evaporator fan gets iced up from water spilling in/on it and air does not circulate. makes a horrible grinding noise before it shuts down. anyway, my icemaker is off right now and that solved the shutdown problem. working on repairing it.
Posted on Nov 24, 2010
RyanFanMan
  • 342 Answers
SOURCE: electrolux fridge not working
There may be a capacitor that runs the motor and may have gone bad. you may want to call someone for service because capacitors are hard to measure for electric motors
Posted on Dec 30, 2011
Electrolux icon side by side fridge is flashing E and F instead of holding the temp for the freezer and fridge. How can I fix this?
Hello Debbie Zymet - Typically error code E and F indicates that there is an error with the evaporator fan in the refrigerator compartment and fan in freezer. I would suggest contacting a professional move forward accurately for proper diagnosing and repair.
Nov 18, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
Error: F 10
That model number does not seem correct but error code F10 on the Electrolux ovens relates to a faulty power board.If that Serial is correct then it is still covered in the 12 months full warranty.
Hope that helps.
May 11, 2010 | Electrolux ICON Designer E30SO75ESS Oven
AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Mar 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Electrolux wine cooler ''af'' code flashing
Aug 30, 2009 | Electrolux Refrigerators
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
E5 flashing error code
I have the same error on my U-Line beverage refrigerator. U-Line said the error indicates the thermostat was out of range for over 12 hours (perhaps due to a recent power outage). My fridge seems to be working just fine so I am not planning on calling a technician until something more serious breaks down.
Apr 25, 2009 | Refrigerators
Electrolux EI24BC65GS Stainless Steel Compact Refrigerator Logo
184 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
