Question about Kenmore Dryers
No heat in dryer model # 96591420
No heat in dryer ! help is there a fuse burnt or element bad?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Things that could stop a electric dryer from heating:
- House fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
Things that could stop a gas dryer from heating:
- Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2009
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
I have no heat going into dryer checked the element and see nothing visually wrong with it. Could there be anything else to look for
www.davesrepair.com/DIYhelp/DIYnoheatdryers.htm -
www.appliance411.com/faq/dryerheat.shtml
use these links above to troubleshoot.
- house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug ...
Apr 07, 2010 | Dryers
THE DRYER IS NOT GETTING HOT EVEN AFTER REPLACING THE COILS. I THOUGHT IT WOULD FIX THE PROBLEM. WHAT NOW?
You have a thermal cut-off . located on the burner box . The box you installed the element . That is probably the part that it bad .
Jul 25, 2009 | Dryers
Not heating
Hi
  • house fuse or breaker ( needs two of them )
  • heating element, burnt wire
  • thermostat(s), thermal fuse ( not all models ),
  • motor heat switch, timer, selector switch,
  • burnt power cord/plug.
You can check these things using an ohmmeter/multimeter from here.
  • glow bar igniter,
  • thermal fuse ( not all models ),
  • coils on the gas valve, gas valve, thermostats,
  • motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 20, 2009 | Kenmore 62802 Electric Dryer
Not drying my cloths . runs but there is no heat
Since the unit will run but won't heat...
The following are things that could stop an electric dryer from heating:
bad heating element(s)
loose, corroded or burnt wire(s)
thermostat(s)
motor heat switch
timer
selector switch
The older the unit the more likely it's heating elements or thermostats
Sorry....this can take some time to diagnose
Apr 10, 2009 | Amana ALE866SB Electric Dryer
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
Mar 07, 2009 | Kenmore Dryers
Maytag Neptune Dryer not heating
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
GLER642A dryer heating element
Things that could stop a electric dryer from heating: - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug
Oct 10, 2008 | Frigidaire GLER642A Electric Dryer
Kenmore electric dryer model#96260100
tim, check to see if your motor switch is stuck. it allows the other power leg to be sent to the heater. comes on when the motor starts turning and releases upon the stopping of the motor. other power leg comes through timer, hope this helps.
Aug 27, 2008 | Dryers
Dryer not going to full heat
Nov 15, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
145 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
