Question about Kenmore Microwave Ovens
What happens if you operate your microwave with nothing in it?
The microwave tube still emits microwaves that bounce around inside the microwave which then hit the source of the microwaves - being the microwave tube, thus damageing the tube( It is like leaving an empty frying pan on the stove on high; the frying pan will burnt and of little cooking value.)
Posted on Jul 31, 2009
Frigidaire microwave model ffmv164lsa constant beeping, with little symbol to the top left hand side of the clock displaying with the beep.
Hopefully no one sprayed a liquid cleaner directly onto or near the keypad...
From page 23 of the owner's manual:
"Wipe the microwave oven inside and out with a soft cloth and and warm (not hot) mild detergent solution. Then rinse and wipe completely dry."
"Clean the outside surface of the microwave with soap and a clean damp cloth. Dry with a clean soft cloth. To prevent damage to the operating parts of the oven, do not let water seep into any vents or openings."
If there is moisture damage, it may dry out by itself if you leave it overnight with the door open. If not, the warranty would be voided and you'd have to arrange for out of warranty service.
If there is no moisture damage, and it failed not due to outside forces, then you should contact the manufacturer to arrange warranty service.
Oct 05, 2016 | Frigidaire Over-the-Range Microwave
How do I fix a microwave oven, display flashes and keys pressed are ignored. It happened after 40 minutes working in convection mode.
It sounds like the electronics are overheating. Be sure all the ventlation is clear and operating.
Dec 04, 2014 | Microwave Ovens
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When the start button is pressed, it clicks a couple times. But, nothing else happens except the timer counts down, the fan doesn't run and the magnatron doesn't operate.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 19, 2011 | KitchenAid KCMS1555R Microwave Oven
Microwave seems to operate normally but does not heat food
Test it. Put a bowl of water in the microwave and place a small (1 or 2 sq inches) piece of aluminum fold next to it. Power the microwave on for 2 or 3 seconds. If the foil sparks, the oven is creating microwaves and should be functioning correctly. If nothing happens to the foil, then you have no microwaves being generated by the klystron tube.
You can spend 80 to 150 dollars to have the oven checked and repaired or you can find another on Craig's List in your community for less than 100 dollars. Alternately, you can replace with a new one for whatever you are able to spend (from 95 to 600 dollars).
Sep 20, 2009 | Maytag MMV4205 Microwave Oven
Sansui Microwave: Nothing Happens when you hit start
there is a safty door switch,if that switch is not making proper contact this thing happens.open the microwave look for safty switch and replace it or if you know how to open it then clean it and it should work
Aug 07, 2009 | Microwave Ovens
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Sharp Carousel Convection ModelRK93S3. Plugged in, not operating
1 of 2 issues is the main 20 amp fuse the other issue could be the thermal fuse..
Dec 25, 2008 | Microwave Ovens
Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
May 09, 2007 | GE JE1540 Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
