Question about Philips 55PP9401 55" Rear Projection Television
Philips 55PP9401 Green Out?
I have a Philips 55PP9401 for about 7 yrs. The picture was "off" so I opened the back. I noticed the blue and red lamps were workinfg but the green. I also noticed the "DP06" light was red while the other lights were green. Is this something I can fix myself? If so, can someone please let me know how (instructions and were to get parts)? Is there a service manual for this TV?
Thank You
  • 934 Answers
This is a PP15 Philips Chassis Designation.
It's based on the DP15 Hitachi Chassis w/ Different Micro.
Hitachi DP15 Model: 53UDX10B
It's most likely that the convergence amps have failed and if you have little experience in electronics I'd STRONGLY suggest you take this one to the shop.
This set takes two STK392-110 Ics and it's recommended you upgrade those to the STK392-150s for greater reliability.
They make a nice kit complete with all conv. Ic's and all (6) resistors and complete instructions. Tritronics carries them part # X480295 (Jt22053 Repair Kit).
Posted on Dec 29, 2007
Well hear goes, I have a Philips 60pp9363 60"
Coolant Fluid is a common Problem ,most of the time it will be the Green and Blue Coolant Fuild that becomes dirty and comtainated
With TV on. Look down into each Tube If it is not clear then change the coolant fuild .
Mats Electronics has Coolant Fuild 1-800-628-1118
Oct 29, 2010 | Philips 60PP9363 60" Rear Projection...
Where do I open the set to replace the lamp
This is a CRT projection TV and does not have a bulb -it has three picture tubes (red, green and blue)
Sep 27, 2009 | Philips 60PP9202 60" Rear Projection...
Bought 57'' philips tv picture fine but red overpowering
should be a knob on the back inside has 3 one for each lamp red green and blue just turn the red down a little
Mar 26, 2009 | Philips 51PP9303H Rear Projection...
Blue crt shot
The coolant in the blue tube has no doubt congealed to an oatmeal like consistancy. Did you notice things like blue halos around things for some period of times. change the coolant. that should correct the blue. this is a common thing for that model as well as all TVs. Blue and green has this happen, Red seems to not have the same trait.
Mar 20, 2008 | Philips 55PW9363 55" Rear Projection...
Yellow tinged edges
Your problem is most likely your Blue and Green lens' inside the light engine. It's not something you can replace yourself. I worked for Philips for 14 yrs. repairing the LCD projectors the last 6 Yrs. Call philips and get the number of an ASC in your area that has repaired projectors.
Feb 14, 2008 | Philips Garbo Multimedia Projector
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
Blue (actual) lamp out of focus. Picture is washed out and milky.
I found a local tv repair guy who sold me the the CRT fluid for $80 and I gave it a go. It wasn't easy, but it worked. If you are really interested I'll tell you how I did it.
Aug 11, 2007 | Philips Magnavox 9P6034C 60" Rear...
No picture coming from red lamp
Sounds like you have two differant problems. A red drive or red picture tube is bad and the conbvergence IC's are bad. To test the red drive disconnect the green picture tube socket BUT MAKE SURE THE SET IS UNPLUGGED!!Then remove the red socket and move over to the green tube. Then turn on the set. If you get the same out of the green then you have a drive problem that needs to be trouble shot for a bad componet. If you do get a picture with the red connected to the green then the red tube is shot. If you know how to read a schematic, get one and then you should have no problem troubleshooting the red drive and the convergence problem. If you dont then there is no easy or quick fix as this is a solid state set and there are no user replaceable parts inside this.,. Your going to need, for safetys sake, call in a trained tech to assist you with this repair
Sep 15, 2006 | Philips Magnavox 51MP392H Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
137 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
