Question about HP Computers & Internet
I have a hp ipaq 111 pda i am trying to reset the device.
  • HP Master
  • 19,396 Answers
To hard reset an iPAQ 111 (you won't find A or B in the manual, if you can find the manual):
A. While on
- press Win + OK + rec together
- while doing that, press reset button
and hold for 3-4 seconds
- release reset
- release buttons
The screen shows "CLEAN RESET" when
this works. It may take a while to
get it all right.
B. Or, if no go,
- leave battery out for 12 hours (?)
C. There is supposed to be a setup assistant
on the CD but I couldn't find that, and even
then, it needs the device to already be
working
from
Posted on Jul 31, 2009
Ipaq 111 hard reset
Soft reset Perform a soft reset
A soft reset stops all running applications, but does not erase any programs or saved data.
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | HP iPAQ 111 Classic Pocket PC
Wont sync with windows 7
If you haven't already done so, try to uninstall and reinstall WMDC on your PC. Reset both your PC and PDA, and try again.
Just my 2 cents... Carlos
Apr 16, 2010 | HP iPAQ 111 Classic Pocket PC
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
Tried to update iPAQ ROM, iPAQ died in middle of Install. Help!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1.) Make sure battery is charged
2.) Locate the rom you want to use
3.) Remove machine fro cradle
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your PDA in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Highlight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from your Vendor in step 3.
10.) The PDA should now begin Flashing the iPAQ's ROM BIOS.
Aug 21, 2009 | HP Computers & Internet
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
Memory on HP ipaq 114.
there are two types of memory my friend
1. RAM
2. ROM both built in PDA
third type is Storage Card u can store music and photos there but u cannot merge it with RAM or ROM so pls try to understand this difference
secondly if u want me to help u out on this memory shortage
then u can reset the device i mean hard reset and re install ur applications by time ur ROM is occupied by some useless files and ur performance is de graded try to refresh ur OS
Hard reset
HP iPAQ Setup Assistant
Use HP iPAQ Setup Assistant to simplify configuring settings on your HP iPAQ.
HP iPAQ Setup Assistant lets you save the settings on your computer. This can help you restore configuration settings on your HP iPAQ at any time. HP iPAQ Setup Assistant also allows you to perform a factory reset on your HP iPAQ and view detailed product information.
To hard reset HP iPAQ 114:
- press and hold the 3 buttons Windows, OK and REC
- press the reset button for about 3-4 seconds and release it
- release the 3 buttons
u can see the video for that but it is in russian lang but self explanatory
http://www.youtube.com/watch?v=BG68AzNBsds
third option is if u want to really get rid of this slow performance and shortage of space just get a clean CUSTOM ROM from
http://forum.xda-developers.com/ for ur PDA strictly at ur OWN RISK
pls rate me fixya if i have fixed ur problem
Mar 01, 2009 | HP Computers & Internet
PIM ino lost from ipaq 1950
did a hard reset. booted up ok. did activesync with my other PDA onto computer and then sync'ed with 1950.
Dec 01, 2008 | HP iPAQ rx1950 Pocket PC
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
Jul 23, 2008 | HP iPAQ rx5915
Pda ipaq 1710 not starting up
press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Jul 16, 2008 | HP iPAQ RZ1710 Pocket PC
HP IPAQ 111 Handheld PDA
If you want to "wipe" the PDA heres how:
-you may need two people to do this,
-hold all three buttons together: START, OK, VOICE
-keep holding these buttons and push reset for 3 seconds
-let go the reset
-then let go the 3 buttons
-the Ipaq will go into CLEAN BOOT mode and start over again
Let me know if these worked.
Feb 11, 2008 | LG KU990 Viewty
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
