Question about Creative Labs Zen MicroPhoto MP3 Player
Player not reconized
Mine was in recovery mode first so i downloaded the recovery tool and did exactly what it was supposed to but now my computer won't reconize player
    Problem Solver:
  • 8 Answers
What operating system are you using? The Zen uses the MTP driver so if you have Vista or are running windows media player 10 or 11 the driver should be present and the device ought to be recognized. If not, check device manager for your zen device. If it's there, right-click and uninstall, disconnect your player and after a few seconds plug it back in. Windows should then reinstall your driver.
Posted on Aug 05, 2009
Frozen
Download the Sansa Recovery Tool from Sandisk's website (make sure the Sansa is not plugged into the computer yet). Once the Recovery Tool is downloaded, connect the Sansa to the computer while holding in the REC button and continue to hold it even after th player is plugged in. It should go into Recovery Mode in 10-15 seconds or so.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa E280 MP3 Player
Recovery Mode
okay okay.
download this tool and upgrade the firmware of ur device!!
its easy but i need fix ya rate okay.
but i need the exact model first
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery Mode
I agree, use the Reload Firmware tool on recovery mode and then upgrade the firmware from the website. If you get "firmware failed!", then try it from a different computer.
May 08, 2008 | Creative Labs Zen Digital Media Player
Help with zen problem
Push the reset button. This worked for me.
Mar 09, 2008 | Creative Labs Zen Stone Plus MP3 Player
Sansa Connect Problem
I had the same problem with my Sansa Connect. It refused to start up when connecting to my computer. I think it may have something to do with not refreshing my music every so often. I tried the Recovery Tool, but it did absolutely nothing. Same problem was still there. So, I did a factory reset and it worked. No problems. I would recommend refreshing music regularly to avoid this problem.
Dec 26, 2007 | SanDisk Sansa Connect MP3 Player
HELP WITH SANSA E260
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 02, 2007 | SanDisk Sansa e200 MP3 Player
I get - 'Load main image failed. Switch to Recovery mode'
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Getting messgae Not enough space for MusicDB. Please free 6MB
If it wont connect to the PC, you need to put it into recovery mode and format it with the recovery tool from SanDisk. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e260 MP3 Player
Recovery Mode
The same problem happened to my sister when she reformatted. All you have to do is go on the internet fine the latest firwire software and download it on to your Zen V Plus.
Sep 05, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
271 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
