Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Will not power down
Every time I turn the printer off it turns back on
    Problem Solver:
  • 5 Answers
U probably have to wait like i do for it to turn off make sure u don't keep pushing the on/off button
Posted on Jul 31, 2009
Mg 5350 6502
Solution 1:
  • Unplug the printer.
  • Remove the faulty Cartridge
  • Plug in the printer and press and hold power button
  • Keep it held down. Press Resume twice, and this should reset the fault.
Solution 2:
  • The last cartridge installed may be faulty.
  • Install a new cartridge
Solution 3:
  • When error is indicated, turn power switch off so green light is extinguished.
  • Hold down resume button and hold down power button so both are held down at same time
  • When green light comes on, continue holding down power button and let resume button go, then press resume button twice.
  • Let power button go.
  • Press resume button four times, power button should be released before doing this.
  • Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on.
Nov 21, 2013 | Canon Office Equipment & Supplies
Tip
For HP officejet printers with "ink system Failure" error : Do this
Unplug the USB cable from the back of the printer if it is connected. Now take out the power cord.
Now Reset the printer:-
To reset it.
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check if it shows the Ink system failure - 0xc19a0027 option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.
or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still exist DO the last step which will reset the whole chip of your printer.
********************Do not do this step unless required************************
( Note :- make sure before you do this step the cartridges should be out of the printer. As it can corrupt your cartridges as well )
************************ Full reset of your printer ********************************
# and 9 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 9 button the hold time )
( On the printer screen it should say Full rest )
If still the problem Exist Call HP as the product has gone bad. The printer will be replaced if it is still in warranty. Remember the printer HP replaces is always a refurbished printer.
HP :- 1-800-474-6836 ( Tech Support )
on May 26, 2010 | Office Equipment & Supplies
Looking for a solution to an error 6502 on canon printer mp510
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Jul 25, 2011 | Canon Office Equipment & Supplies
Error 6502
Dear Asker
how would i know this error is for which printer so i am assuming it's cannon.
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error mesaages like 6502 or other types of error meaasge to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
Incidentally, you may find that if the chips had previously been disabled,the low ink warnings are showing againand they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be usefull if you need some warranty work done on you printer after the chips had been disabled. Canon does warn that disabling the chips may result in the printer's warranty being voided
Feb 28, 2011 | Office Equipment & Supplies
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
Printer shows no cartage found
Partial reset :-
Now try to turn on the printer and check. If it works Perfect. If not then do this :-
Semi-Full Reset:-
May 11, 2010 | HP PhotoSmart C4385 All-in-One Printer
I have an error message on my HP Photosmart Premium C309a - "Ink system failure - 0xc19a0027 - Please turn printer Off and then On" - I have done this as well as replace all of the ink cartridges &...
Unplug the USB cable from theback of the printer if it is connected. Now take out the power cord.
To reset it.
Partial reset :-
Semi-Full Reset:-
May 06, 2010 | HP Photosmart C5180 All-In-One InkJet...
Eror 6502
Oct 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Power Problem
power down only apply if you power down button put the hold 5 second printer automatic power down after that u unhold
Feb 26, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
