Car Audio & Video Logo
A
Anonymous Posted on Mar 30, 2018
Aux how do i use the aux port - Car Audio & Video
The AUX button says SAT 1, SAT 2, AND SAT 3. It does NOT say AUX Line In and does not recognize anything plugged into the aux port. What can I do to get the AUX port working???
Make sure whatever is plugged into the Aux port is the proper size and configuration (2-lead, 3-lead; 3.5mm, etc) as far as the cable, is properly seated (not so big that it doesn't fit all the way in) and that the device is on. Most Aux inputs don't activate unless there is an active signal coming in.
1helpful
Where is the AUX connection on the radio
There is no port. There should be a ten wire bundle (5 pair) coming out of the back (next to the power port). One pair of wires should be labeled aux in.
What is the aux button on my remote
you likely have an aux port on the product that the remote controls, it allows your device to open up the pathway to the aux port. eg if it is a sterio unit, then the aux could be a digital tuner, or if a TV the aux could be a video player etc
Just purchased a Goodman 50 w sound bar connected to AUX on tv and sound bar clicked AUX on remote white light shows no sound just a loud buzz
To the best of my understanding an Aux port is usually an input port. So you might be sticking the sound bar terminals into the wrong connector in TV. The audio signal from the TV is meant to go into the Aux In port of the sound bar. Usually this will mean a pair of RCA cables (white and red) from TV out to Aux In. If you have done the right things then maybe check if soundbar is not in mute. Try some other source as well. Like connecting an iPhone or ipod stereo out to the Line In port in soundbar and selecting LineIn mode.
see page 7 in the soundbar manual. It is hard to know what TV connection you are using. Is it selected on the TV settings? http://www.goodmans.co.uk/support/downloads/user-guides/GDSB02BT20-ib.pdf
1helpful
My aux inport won't work on 2006 Land Rover LR3. Would this be something effected by a bad fuse?
No. Radio works off single fuse. Some aux ports have to be enabled by mode/source setting. Check your radio manual on how to turn on aux port.
2helpful
Can I use the Aux port to play USB in Ford audio/CD MP3 player
hi, you may use the aux port by using the right type of usb, hope this helps
Aux cable snapped of inside external Audio port (AUX). an ideas on how to get the piece out? or does anyone now how to take the AUX port out of the console? 2008 crv, center console unit.
I have a 2007 CRV which had the same issue. I fixed this by:
- first removing the AUX port cover by carefully prying it up from both the rear-facing and front-facing edges. Once done, this exposes the AUX port mechanism itself.
- Using some needlenose plyers, I pulled out the AUX port component. It simply slides out.
- The trick now is to PUSH the broken piece out of the inside of the port. To do this, I first removed the "cover" that is covering the end of the port (opposite from the opening to the port). Be very careful with this step as you don't want to break the cover. It's very thin plastic.
- Once this cover is removed, I used a pin to push the piece that was lodged inside back out of the opening.
Reassembly was the opposite of this and was quick.
Hope that helps.
- Dave
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
