Export data in excel sheet and in specific column
I did not write this but look towards the end of the code and it will give you an idea on how to do it
Sub ExportToExcel(strOutputFile As String, Optional boolSuppressMessages As Boolean = False)
Dim strTemplateFile As String
Dim fso As Scripting.FileSystemObject
Dim cnn As ADODB.Connection
Dim rstTarget As ADODB.Recordset
Dim rstCustomers As ADODB.Recordset
Dim rstServiceReps As ADODB.Recordset
On Error GoTo ErrorHandler: On Error GoTo 0
Set fso = New Scripting.FileSystemObject
' Get template file path
strTemplateFile = CurrentProject.path & "\CompaniesEmployeesList.xlt"
' Copy template to the target
fso.CopyFile strTemplateFile, strOutputFile, False
' Open a connection to the workbook
Set cnn = New ADODB.Connection
cnn.Provider = "Microsoft.Jet.OLEDB.4.0"
cnn.ConnectionString = "Data Source=" & strOutputFile & ";" & _
"Extended Properties=""Excel 8.0"""
cnn.Mode = adModeReadWrite
cnn.Open
' Open the target recordset (the Excel sheet)
Set rstTarget = New ADODB.Recordset
rstTarget.Open "SELECT [ID], [Name], [City] " & _
"FROM [Sheet1$]", cnn, adOpenDynamic, adLockOptimistic
' Open Customer data recodset
Set rstCustomers = New ADODB.Recordset
rstCustomers.Open "SELECT CompanyID, CompanyName, City " & _
"FROM Customers " & _
"WHERE City = 'Madrid' " & _
"ORDER BY CompanyName", CurrentProject.Connection
' Open Service Rep data recodset
Set rstServiceReps = New ADODB.Recordset
rstServiceReps.Open "SELECT EmployeeID, [LastName] & "", "" & [FirstName] AS Name, City " & _
"FROM Employees " & _
"ORDER BY [LastName]", CurrentProject.Connection
' Loop through Customers result set and copy to target
Do While Not rstCustomers.EOF
rstTarget.AddNew
rstTarget![ID] = rstCustomers!CompanyID
rstTarget![Name] = rstCustomers!CompanyName
rstTarget![City] = rstCustomers!City
rstCustomers.MoveNext
Loop
' Insert blank line between result sets.
rstTarget.AddNew
rstTarget![ID] = ""
rstTarget![Name] = ""
rstTarget![City] = ""
rstTarget.Update
' Loop through Service Reps result set and copy to target
Do While Not rstServiceReps.EOF
rstTarget.AddNew
rstTarget![ID] = rstServiceReps!EmployeeID
rstTarget![Name] = rstServiceReps!Name
rstTarget![City] = rstServiceReps!City
rstTarget.Update
rstServiceReps.MoveNext
Loop
rstTarget.Close
rstCustomers.Close
rstServiceReps.Close
cnn.Close
If Not boolSuppressMessages Then
MsgBox "Workbook Created", vbInformation + vbOKOnly, "ExcelExport"
End If
ExitHere:
On Error Resume Next
Set rstTarget = Nothing
Set cnn = Nothing
Set rstCustomers = Nothing
Set rstServiceReps = Nothing
Exit Sub
ErrorHandler:
Eval "MsgBox(""Error " & Err.Number & "@" & Err.Description & "@"")"
If Not cnn Is Nothing Then
cnn.Close
End If
Resume ExitHere
End Sub
