Question about Jenn-Air JGS8750 Gas Kitchen Range
Fault code f9 appears - Jenn-Air JGS8750 Gas Kitchen Range
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F9 means Door latch supervisory- Check door lock circuit or rebuild clock assembly (also called the ERC).
You can clear this error code by replacing door latch assembly completly, before that you can check the latch wiring.
And, if door is stuck and you are unable to open the door then take a long hard wire & make a small hook at one end and insert it from the left side gently for the door latch hook and pull it over to un latch the door. After this restart the gas range and check if code appears again, if its still there then replace the door latch assembly completly.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2009
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
Error Code F9.Q (Touch Communication).
KitchenAid Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Kitchen-Aid-Appliance-Fault-Codes.aspx
Fault codes for a number of KitchenAid appliances, including two and four digit codesfor ... F9 - Oven Door Lock Failure - Check door lock switches and wiring.
Jul 27, 2015 | KitchenAid KHMS2050SSS Microwave Oven
MAYTAG OVEN SHOWING A F9 CODE. I PRESS THE CLEAR BUTTON, AND A FEW SECONDS LETTER THE CODE APPEARS AGAIN. WHAT IS CAUSING THIS CODE. OVEN WAS USED EARLIER AND HEATED JUST FINE.
Hi rosebud1239,
The F9 fault code error description is about the door latch. Please check the door latch components.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MGS5770 Gas Kitchen Range
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
The F-9 code comes up when we try the oven. We
Hi tessjon,
The F9 fault code is about the door latch, please check the door latch components.
Hope it helps.
Jan 09, 2010 | Maytag MER5775Q Electric Kitchen Range
What does F9 mean? Won't allow me to use the oven
F9 -It is a Door latch fault code
Check door latch components.The stove is not detecting a proper door close.Or else there might be some metal blocking the door from closing.It should solve itself in few hours else you might have to replace the door latch system.Good luck with the machine.Please do post comments.Also do rate the solution.Thank you in advance.
Apr 10, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Getting F9 Code & beeping
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
Mar 24, 2009 | Maytag MGS5770 Gas Kitchen Range
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JGS8750 Gas Kitchen Range Logo
305 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
