Question about Durabrand Anti-Skip CD-915 Personal CD Player
Disk won't play
The disk won't play, but the radio does work
0 characters
1 Points
Memorex mp4047 Personal CD Instructions needed
You may download a copy of the user's guide here.
Dec 19, 2012 | Personal CD Players
When you put the cd in it dos'ent work
does the CD that you put in that doesn't play are the CD you use before and plays on your CD player?If yes then that is a lens issue the lens probably need replacement
try to clean first the lens of the player with a soft cloth dip in an alcohol wipe the lens do not apply too much pressure when wiping
are the CD format compatible with your player there are different audio formats which we must consider with the compatibility with the player CD,MP3,MIDI,VCD,DVD,MP4 etc.your player must support this format to play this disk.
The primary cause of disk reading failure is the lens itself .if your CD player is more than 3 years old then it must be the lens to replace next is the spindle motor this motor is the one spins the disk the life span of this motor is 4 to 5 years this are the things to consider and you can decide which part needs relacement
thank you and good luck!
Dec 12, 2010 | Starlite NextPlay SkipFree Personal CD...
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
May 01, 2009 | RCA Personal CD Players
Sony CD Walkman sees but won't play disk D-NS313F
Try holding down the play or fast forward button while the disk is loading or drop it onto a carpet from a height of 1-1.2 feet. worked for my sony playstation 2...or shake it violently while on but with no disk inside ...... Hope this helps!
Jan 22, 2009 | Personal CD Players
Insignia NS B2110 boombox CD not playing
Try an audio CD which has been purchased. I think you have MP3's on your cd and your boombox maybe does not support MP3
Mar 07, 2008 | Insignia Sport lDM9700-2 Personal CD...
Cd function not working
you can always try cleaning the lense and if that dosent work exchange it for a new one
Feb 01, 2008 | Jwin JX-CD780 Personal CD Player
CD will not play
Have it checked by a technician, common f15 errors are caused by the cd players lid not being closed, you need to see if the protruding plastics inside your cd player pushes the closed lid detection properly. If not, it needs some manual disassembly...
Dec 08, 2007 | Panasonic SL-CT582V Personal CD Player
Blinking MP3
is it an mp3 disk some cd players like this one I think does not sopport mp3 disks. (Try it another disk see if that works) ~Grim
Dec 09, 2006 | GPX CDPM5004 Personal CD Player
Durabrand Anti-Skip CD-915 Personal CD Player Logo
24 people viewed this question
Top Durabrand Personal CD Players Experts
Todd Zettlemoyer
Todd Zettlemoyer
Are you a Durabrand Personal CD Player Expert? Answer questions, earn points and help others
