Question about Samsung AH5900092W Remote Control
How to switch from tv to dvd
I had a samsung ht-x50 dvd player installed at home. but, they did not give me an owner's manual. when the tech was here, he gave me instructions on how to switch from tv to dvd player. but, i can't seem to make it switch now.
the tech told me to hit dvd receiver, then 'dvd tv', then tv video. but i don't see 'dvd tv' button.
can you help?
3 Suggested Answers
SOURCE: My remote for the samsung htc550 home theater
Press the BD Receiver / TV button twice in quick succession. The light should now be orange which indicates it will operate the Home Cinema system....Pressing it twice again in quick succession will turn the light green indicating it will operate the TV.....Unfortunately the useless operator manual with the system does not tell you this....
Posted on Dec 18, 2010
  • 1637 Answers
SOURCE: The remote control for my
Remove the batteries then reinsert them. If the problem persists, please change the batteries.
Posted on Jan 08, 2011
  • 23 Answers
SOURCE: Samsung DVD Remote contol: Cannot
Hello, take the batterys out wait 15 minutes and put it back it will work if not change the batteries.
Posted on Apr 03, 2011
0 characters
1 Points
Samsung HT-P38 remote will only turn TV on and off won't control the stereo receiver, why?
If stereo recieiver is part of your Samsung HT-P38, remote should have a function to contole it. Check user's manual
Samsung HT P38 Instruction Manual
If you are following correct steps for use of your remote and still can't manage your stereo receiver, probably something is not working correctly., most probably your remote. Maybe you could get it checked with an authorized SAMSUNG repair service
Jul 14, 2014 | Samsung TV Remote Control
Is there a code for samsung DVD VR-357
Just checkout with these setup codes. Sony RM-V210T remote has these setup codes with Samsung DVD
0014, 0212, 0229
Oct 28, 2011 | Sony RM-V210T Remote Control
Codes for bp59-00016 samsung remote to hook up a rca dvd player
Try the code 002 for an RCA DVD player for the BP59-00016 remote. This is the only code given for RCA DVD players for several Samsung TV universal remotes (BP59-0007 and the BP59-00016A). A manual for a TV with the BP59-00016A remote is here: .
You may need to check the age of the remote. The codes in a universal remote generally only control those devices released 6 months or more before the remote was programmed. If your RCA DVD player is newer than your remote, you may need a new remote.
I hope this helps.
Oct 12, 2011 | Samsung BP59-00016A Remote Control
I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
Need the model number of the samsung Home home theatre system to give to correct code.
Aug 13, 2011 | Remote Controls
I have a Samsung HT-BD3252 Home Theater/Blu-Ray combo and I'm looking for a Comcast remote code that works. I've tried several, including appending a 1 and a 2 to the 4 digit codes given for Samsung DVD...
Turn the TV on, on the remote, press and hold SET-UP until the light blinks twice,then release, enter 9-9-1, the TV key will blink twice,aim the remote at the TV and press and hold POWER and TV slowly alternating from one to the other, stop when the TV turns off, press SET-UP the TV key will blink twice....hope this was helpful...
Apr 24, 2010 | One For All URC-9910 LCD Remote Control
Need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
May 04, 2009 | Samsung TV Remote Control
Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Feb 14, 2009 | Logitech Harmony 880 LCD Remote Control
Need vizio code for Samsung remote!!
I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
Jul 25, 2008 | Zenith ZEN700 Remote Control
Samsung AH5900092W Remote Control Logo
363 people viewed this question
Top Samsung Remote Controls Experts
andy williard
andy williard
Are you a Samsung Remote Control Expert? Answer questions, earn points and help others
