Question about Epson Stylus DX4850 All-In-One InkJet Printer
Ink cartridges are full, goes through al the motions of printing, but no print on the paper
  • 108 Answers
The nozzles might be clogged. Also the clear encoding strip behind the carriage might need cleaning. If cleaning these doesn't work. It might need parts.
Posted on Jul 31, 2009
  • 21 Answers
Has the printer been sitting a long time since the last time you printed? If so the print heads may be clogged, run the cleaning program to try getting them to flow again
Replaced ink cartridges, printer goes through all the motions, but paper comes out blank. I have done all the maintenance steps. What gives?
Cannon ink cartridges go into a print head. This is normally a removable box the ink cartridge sits in.
First remove the head and the cartridges from it. Now try this to clean the old ink off the print head, rub/soak the print head in alcohol. Make sure the print head is complete dry and place the ink back in it and return to the printer. Try to print a page, if you have the same results you need to replace the print head.
Jul 21, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
Will not print on paper
if the cartridges were out of the printer for any length of time the ink has dried up on the print heads. you most likely will have to replace the ink cartridges. then allign again before it will print correctly
Apr 04, 2010 | Lexmark JetPrinter Z22 Color InkJet
Hi,I am experiencing nothing printing on paper even though ink cartridges have been replaced and cleaning has been performed.ink absorber warning appears and says that absorbers are almost full and to push...
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Dec 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printer not printing. Printer goes through the motions, but nothing on paper. Ink cartridges are full
1. Make sure plastic (all of it) is not on the cartridge contacts.
2. Wipe the print area (bottom of cartridge) with damp cloth, If does not work, try warm water - even letting it stand for a few minutes.
3. Go to the printing services and service the device (this function let the printer try to clear any clogged areas that may exist.
Jul 08, 2009 | Lexmark X7170 All-In-One InkJet Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
Nothing printed when paper goes through printer
the ink nozzles on the cartridges are clogged. first try cleaning them using a alcohol-soaked Q-tip against the shiny part where ink comes out (remove cartridges first). if still no ink, cartridges may be out of ink, so either replace or re-fill them.
Oct 28, 2007 | Lexmark Z600 InkJet Printer
Epson Stylus DX4850 All-In-One InkJet Printer Logo
333 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
