Question about Garden
Echo SHC-212 hedge trimmer starts and runs briefly but will stop running afterwards.
    Scholar:
  • 173 Answers
If it has not had a service recently, it's probably due by now.
Just take out the spark plug, and if it's black, or 'coked' up, just show it a wire brush.
Also, remove the air filter, and if you have one, show that, a compressor. (or alternatively, just bang it about a bit, till all the loose debris, and collective build-up, are removed.
Afterwards, (if that doesn't solve the problem),
you can adjust the timing, quite simply, by closing, or opening, the gap on the plug.
Or you can open or close the space between the contact, and the magneto.
Both can be very 'effective' means of adjusting the timing.
If problems still persist,
you know who to ask.
P.s. and don't forget to give the thumbs up ;)
Posted on Jul 31, 2009
My echo 210 primer bulb does not fill only pressurizes the tank
The fuel line hook up is wrong. Ok, so look at the two nappies on back of the bulb assy. The long nipple is for the fuel return line, (the line without the fuel filter that returns to the tank) the short nipple , that line goes to the fuel barb on the carburetor, on the same side as the bulb assy.. then on the opposite side of the carburetor find the fuel barb, connect the fuel line to that barb and into the tank where the fuel filter is on the end of that,... If you have trouble understanding what I mean, hmu.
Brian
Sep 23, 2015 | Echo Shc-210 Professional Extended Reach...
Echo hedge trimmer replaced carburator still wont start getting spark
Hi, There are 3 things that you need for the motor to start.
1) Fuel 2) Air 3) Spark. Check all 3 and it should run. Good luck.
Jul 27, 2015 | Echo Garden
Echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Nov 26, 2013 | ECHO, Inc. 20 In. Double Sided Hedge...
Echo hsc 225 hedge trimmer throttle sticks
I would suspect a defective throttle valve ( carb ) try this, three screws on top ( by throttle valve ) loosen them slightly and see if this frees up. If not find a dealer and get a new carb. You now know what damages ethanol causes.
Nov 12, 2013 | Echo SHC-225S Hedge Trimmers
My Echo SHC-212 floods out and will not start. Even with no choke and throtle wide open it will still flood cylinder. I have good spark.
Check your choke prime bulb and carburetor lines - sounds like its clogged and gas is barely leaking into flood the cylinder
Jan 25, 2013 | Echo Garden
My Echo SHC-212 will start and slow idle but when I give it gas it boggs and stalls. I've changed the spark plug and I'm using the proper mix. Any suggestions? I was thinking of trying to clean the carb...
The prior posters must be from the Briggs & Stratton era :0] This is an EPA carb. You can only adjust the idle speed. The Echo SHC-212 uses the Zama RB-K75 carb.
My SHC-212 had the same bogg/stall symptoms. I had to disassemble and clean the carb to get rid of it. There is an internal filter screen that sometimes clogs. I soak and use compressed air to blow out all orifices. But the real problem is leaving ethanol gas in the carb during storage. It warps the delicate gaskets/valves. So buy Zama rebuild kit.
Dec 24, 2010 | Echo Zama Carb Kit For Shc212 Hedge...
Echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Nov 01, 2009 | Echo 21.2 CC Shafted Hedge Trimmer
Garden Logo
473 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
