Question about Maytag Neptune MAH5500B Front Load Washer
Neptune front loader (help)
Will not turn electricity getting to it. have checked my breaker and socket. machine is 18 months old.
  • misterray Nov 25, 2007
    washer will not operate, have electricity, all lights on front panel lite up but get a d5 code when try to push wash button. Have checked door several times. Door is closed and locked
  • 249 Answers
7 out of 10 its door lock, is door locking??
Posted on Nov 24, 2007
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
Jun 13, 2013 - Uploaded by
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Front loader washing machine not turning on as if the power isnt on at all.
check power line terminal for voltage, u did check the home socket to be sure ur breaker is not out?
Sep 28, 2014 | Washing Machines
Washing machine was operating machine stoped 10 minutes after operating and will not start water is in the machine it did not drain
Hello, first check if the breaker triped in the electrical panel box (fuse box--old name). If it has not triped a breaker. Unplug your washing machine and wait about 10 or 15 second and replug the washing machine into the electrical socket. Don't turn it on. There should be a reset button. Push the button first, then turn on your washing machine. I hope this works for you. GB...stewbison.
Aug 25, 2011 | LG WM-2277HW Front Load Washer
"ZWF160070W1 Washing machine. Only 18 monthe old!
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Nov 14, 2010 | Zanussi WJD1257W Front Load Washer
I have Maytag Neptune front loader washer. When
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will not spin, lock light out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jun 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH 4000AWW works good but some whater is left
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
Apr 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
Service light is on my whirlpool washing machine and won't allow the wash to start, can I override this as it's only 18 months old?
The main motor in the whirlpool front loaders has brushes. These will wear out eventually. Does the drum try and turn when a load is started? If not the motor deserves a check. 18 months sounds short but possible. Mine took 4 years to wear down.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
106 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
