Question about Dell Vostro 420 Desktop Computer
Vostro bios post beeps
I get 2 beeps and ive tried many things including cleaning the memory sticks with a cloth and a eraser since it was recomended in one of the posts tried removing the cmos battery and calling the president for advice
none of them worked i guess maybe my memory sticks are broken
hope someone can help my vostro 400 to stop crying every time it boots
I will give u Cookies if u help me MAYBE MILK!
  • 3 more comments
  • messawood Jul 31, 2009
    2 and by diagnostic lights i guess u mean the power button? then blue
    it's the only 2 sticks that came with the computer
  • mtbakercs
    mtbakercs May 11, 2010
    hello, how many beeps does your system make? and are their diagnostic lights?
    President:
  • 2,976 Answers
Either your memory sticks are bad or, you have too much memory in the slots. Computers can accept a lot of memory but they can only recognize a certain amount. Make sure you don't have too much.
Posted on Jul 31, 2009
I have an acer aspire ax1430-uw30p boots up, but screen stays black, cant even see setup menu, can someone help please...
Try resetting the Bios. Remove the ram chips and if you can get access to it, the button battery on the motherboard. Wait a few minutes then put it all back in and boot up. If that won't work, try the steps at the link below, or try them first if you prefer.
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Feb 18, 2015 | Acer Computers & Internet
2 short beep
Ram Memory problem.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Lay a soft static free cloth on the TABLE you're working on.
Turn the laptop over, lay it on the cloth.
Open the Memory Compartment.
Remove all ram memory modules. ('Stick')
Clean the gold plated contact pins on the bottom, of the ram memory modules, with a pencil eraser.
Handle the ram memory module by the BODY.
The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins.
The Body is coated with a see-through protective plastic.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
If you are using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band of the pencil, touch the gold plated contact pins.
Rub up, and down, and across on the contact pins, BOTH sides.
Doesn't take much pressure, nor rubbing.
Contact pins will clean up, but they may not be bright, and shiny.
It's OK. I assure you that you have cleaned them. Doesn't take much 'corrosion' to make a bad contact surface.
Use air to remove the eraser dust. If you have a can of compressed air for computers, use it. If not air pressure from your mouth will be sufficient.
Reinstall.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 16, 2012 | EliteGroup 600L Notebook
WHEN I TURN ON IT BEEP
Helen the beeps you hear are BIOS Beep Codes. The computer's method of telling you something is wrong, and an area to look into for it.
As the name implies, the beeps are in a code pattern.
For one example, the computer may beep 2 Short beeps, or 3 Short beeps, then a pause, then start over.
This means a memory problem.
Solution is to;
1) Remove ALL power to the laptop.
Remove the AC adapter (Charger) and Battery.
2 Laptop closed turn it over on a table, that has a lint, and static free towel on it. (Protects the table, and the laptop)
3) Locate the Memory Compartment Cover. This panel goes by different names. The Ram Memory is located inside.
Remove all Ram Memory module/s. ('Stick')
Handle the Ram Memory module by the Body. Refrain from touching the gold plated contact pins on the bottom.
(Everywhere but the gold plated contact pins on the bottom, is coated with a see-through protective plastic,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png )
'Corrosion' develops on the contact pins at the bottom. This makes a bad contact. Doesn't take much corrosion, to make a bad contact.
(Gold does not Corrode. It does develop a 'patina' to the surface, though)
Use a pencil eraser to clean each contact pin.
(There are usually gold plated contact pins, on both sides of a Ram Memory module. Clean both sides, and all contact pins)
If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band, contact any ram memory module contact pin.
Bottom of a Ram Memory module is where the contact pins are.
Clean the contact pins by rubbing the eraser on each one, from top down towards the bottom.
{Doesn't take much to clean the contact pin. You do not have to rub hard)
After you are satisfied the contact pins are clean, use air to remove the eraser dust.
You can use a can of compressed air for computers, if available, or air pressure from your mouth will be sufficient.
Reinstall all Ram Memory modules correctly. Close the Memory Compartment Cover.
Attach the Battery, Plug the AC adapter back in. (AC adapter to power, also)
WAIT 1 minute, turn the laptop on.
Post back in a Comment as to your findings.
Regards,
joecoolvette
Feb 04, 2012 | Computers & Internet
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
It beeps five times and no picture just five beeps
The beeps you hear is a BIOS Beep Code.
The computer's way of telling you something is wrong, and an area to look into for the problem.
The BIOS Beep Code is sort of like Morse Code.
Instead of a series of dots, and dashes, it's a series of short beeps, and long beeps.
One example:
One short beep, two long beeps.
Then a period of silence, and the beep code starts all over.
There are different BIOS manufacturers that make the BIOS program.
(Basic Input/Output System)
Two of the main BIOS manufacturers are AMI, (American Megatrends Inc.), and Award/Phoenix.
(Award and Phoenix used to be two separate manufacturers, but have combined)
5 short beeps sound like one of AMI's BIOS Beep Codes.
http://www.pchell.com/hardware/beepcodes.shtml#ami
Part of the information given states to remove the ram memory module/s, ('Sticks'), and reinstall them.
I would also like to add to clean the gold plated contact pins, on the bottom of the ram memory modules.
Computer off, unplugged from power, and computer case open, observe Anti-Static Precautions BEFORE reaching inside your computer, and handling the ram memory module/s.
Use a pencil eraser to clean the gold plated contact pins.
Example of a DDR Sdram ram memory module, and it's gold plated contact pins,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the photo to enlarge. You can enlarge twice)
The top of the ram memory module is towards the DRAM chips. (Black rectangular objects)
The bottom of the ram memory module is where the contact pins are located.
Suggest use the eraser on the top of each contact pin, stroking down towards the bottom of the contact pin.
If you are using an eraser on the end of a pencil, refrain from letting the metal band touch the contact pin.
Now use air to remove the eraser dust.
You can use a can of compressed air for computers, if one is readily available, or air pressure from your mouth will be sufficient.
Reinstall the ram memory module/s.
Close the computer case, plug the computer back into power.
WAIT 1 minute, turn the computer on.
Sep 15, 2010 | Computers & Internet
No post no video Beeps once every sec. The first few times it boot I had video. Then lost video now I have it back. it will run all day when in the bios. But outside the bios trying to load Windows XP home...
Hi...
Actually the problem is the memory witch is beeping every seconds during turning the laptop on. Check your memory stick, remove the memory stick, clean from dust. Reinsert it try to use the other memory slot. If the problem is still occurs the memory stick is bad or faulty already. You need to replace the memory stick.
Thanks for using fixya
Regards
PCmania
Aug 15, 2009 | Toshiba Computers & Internet
Dell vostro 400 2 beeps in bios post test
Hi...
The cause of beeping is the memory problem. maybe the memory stick is not inserted correctly. If your memory stick will not correctly inserted it will damaged the memory slot. Try to use the other slot, if the same thing happen. You memory slot will be damaged you need to bring you motherboard to the computer repair center. Ask first how you will pay, if the labor cost is high. its better to buy a brand new motherboard.
Regards.
ICmanServer
Aug 01, 2009 | Computers & Internet
I put 1gb memory stick first slot no boot up
the bios may not support the bus speed of the ram or they maybe some dirt on the brass contacts, clean these with a standard eraser, make sure its pushed into the dimm slot properly ( you'll hear 1 or 2 clip sounds ) check your motherboard manual to see if it supports the bus speed, if it does put your old ram back in boot windows and flash the bios ( download bios update from motherboard manufacurer's support website ), if you have no ram you have get some and flash through windows, you can also flash the bios via floppy ( THE "FLOPPY" METHOD IS NOT RECOMENDED ) if it goes wrong you'll kill the motherboard
good luck
Nov 14, 2008 | Siemens D1675 Motherboard
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
Two long beeps and no booting. Motherboard Soltek SL-75FRN2-L. The computer has worked with this motherboard for about 3 years. The problem started like that: first problems with the hard disk with the...
You could try re-seating your ram and your video card if applicable.
2 beeps generally upon post depending on the bios is video or unstable ram.
Depending on how many sticks you have on the board try re-seating them if that doesn't work diagnose the faulty stick by putting them in 1 at a time.
Hope this helps
Jan 19, 2008 | Soltek SL-75FRN2-L Motherboard
Open Questions:
Fixed amber light - start,shut down itself and restart itself Hello, Yesterday morning, I have installed a second screen linked to my graphic card. I tried to install a 3rd screen on the VGA motherboard, and it didn't work so I take it off. I could work on the computer with the 2 screens all day long. I left my office and the screensaver started. When I came back, I couldn't started my computer and my screen didn't light on after moving the mouse or writting on the keyboard. Then, I shut down my computer to restart it. Here is the problem. 1) The power light was fix and amber, the ventilation works. 2) 2-3 seconds later, it shuts down itself for few seconds 3) And it restarts itself. However, I still have the fix amber light and the screen is not activated. I checked the wall plug, I reduced the number of device on the trailling socket. I removed and reinstalled from the motherboard the RAM memory card and my graphic card. I tried with only one screen. But I still have the same problem. Do you have any ideas about what the problem could be: - Is the motherboard over? - Is the graphic card over? - Is the power bloc over? How could I evaluate which component is not working correctly? Thanks for your precious help. My configuration : - Intel Core 2 Quad Q8200(2,33GHz,1333MHz,4Mo) - Windows Vista - Cordon d'alimentation : Européen 2M - Carte graphique : 256Mo DDR2 ATI Radeon HD 3650 (pleine hauteur,sortie DVI/HDMI/DisplayPort,Double affichage)
Mar 01, 2017 | Dell Vostro 420 Desktop Computer
Dell Vostro 420 Desktop Computer   Logo
719 people viewed this question
Alun Cox
