I have a problem with the keyboard on Dell C600 laptop. It seems like the left part of the keyboard is disabled. No respons on 1,2,q,w,a,s,z,x,Esc. I purchased a new keyboard on eBay, but it didn't fix the problem. I resoldered a keyboard connector on the system board, no change. Please help!!!
  • Yuriy Beznos
    Yuriy Beznos Aug 05, 2009
    Thank you to isamb.
    The keyboard connector didn't look as bad, but I still decided to go ahead with the isamb recommendations. I used a needle to pool all the pins away from the edges then reconnected the keyboard back and it worked.
  • RichTheNoun
    RichTheNoun May 11, 2010
    Did you try hooking up an external keyboard? If not, try it and see if you get the same results. Any USB keyboard should work.
  • 21 Answers
The C600 keyboard connector is a ribbon cable with a push down to connect block. When one side of the keyboard keys do not work it is usually because the pins in the keyboard socket do not make a good contact with the ribbon cable.
Remove the keyboard and visually inspect the pins in the connector.
If necessary you can prise them back into the correct position using a sewing needle or something similar to get behind the pins.
Make sure you discconect the power supply and battery before you attempt.
Posted on Jul 31, 2009
Where do I turn off my laptop
Power button is top left corner of keyboard above the "Esc" key.
If you are trying to shutdown from Windows 8, follow these steps:
1. Mouse over the little gadget in the lower right corner of the screen. (You can also move your mouse cursor to the upper left corner; same result. Or, you can press Windows-C on your keyboard.)
2. In the slide-out menu (known as the Charms Bar) that appears, click Settings.
3. Click the Power button, and then click your desired action: Sleep, Shut down, or Update and restart.
Mar 07, 2014 | Dell Computers & Internet
My left and right keys on my mouse has swapped functions, can i put right
go to start->settings->control panel and Double click on mouse icon and Uncheck switch primary and secondary buttons under Buttons tab. and Click apply and OK. now it will work fine
Jan 26, 2010 | Dell Latitude C600 Laptop Keyboard 47NVF
Some keys on my old dell latitude c600 are not working
it happens, even i have DELL 610 notebook that has some keys not working, the only option is to change the keyboad layout.....
in India all parts can be replaced/repaired but abroad is a different story....the reparing cost is equal to the new....just trash the laptop once it's life is thru....
Dec 06, 2009 | Dell Latitude C600 Laptop Keyboard 47NVF
Dell d600 Keyboard problem. i think only a Genius can solve
1. If you can open dell laptop keyboard clean it underneath. There might be some static problems and dirt must have the cause of it.
2. Second, try virus scan that might fix the problem.
Jun 19, 2009 | Dell Latitude D600 Notebook
Dell c600 problems with: charging/keyboard/pointing device
you can try online antivirus scan firstly, like NOD.com, AVG.com. If everything is OK, try to reinstall OS,or RMA
Feb 13, 2009 | Dell Latitude C600 Notebook
C400
Yes, you can use the c600 if you wish.
Correction on myself: There is 1 screw on the bottom left right above the Windows XP OEM Sticker. Remove that, the hard drive slides out.
Hope this helps.
Jordan
Jan 15, 2009 | Dell Latitude C400 Notebook
I have a dell c600 and my hardrive isnt recognised
go to the bios while restarting your laptop and there is option to disable sata for hard drive disable sata you hard drive will probably start working
Dec 05, 2008 | Dell Latitude C600 Notebook
INSTRUCTIONS
Hi
Check Keyboard Assembly on Dell Latitude C600 - http://support.dell.com/support/edocs/systems/latc600/sm_html/remove.htm#999019
Mike
Mar 08, 2008 | Dell 0Y3740 Keyboard
DELL C600 Ethernet ports quit after installing mcpcia wireless
Try device manager and see if they are disabled. I've seen this happening a few times
Sep 29, 2007 | Dell Latitude D600 Notebook
Computers & Internet Logo
David Payne
David Payne
