Question about Apex Digital PF3220 32" TV
Horizontal image is stretched beyond the screen borders
The image (Apex pf3220) is stretched horizontally beyond the borders of the tube. How do I adjust this? Can this be done without remote? ...which I do not have. Thanks!
  • 378 Answers
The problem is inside your TV , check the capacitor in vertical section of the TV.
Posted on Jul 31, 2009
Can I adjust timing chain on a 1999 ford f150 5.4L without removing engine?
There is no real timing chain adjustment. If the timing chain is loose, it is because it has stretched beyond the ability of the tensioner to compensate. You'll need to replace the timing chain. (Yes, it can be done without removing the engine, but it's a tight space!)
May 15, 2015 | 1999 Ford F150 Regular Cab
Hcl moniter screen adjust problem
hi. this may be from EEPROM IC. you can program it or replace IC with new one and then program it.
Apr 27, 2015 | Computers & Internet
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
I have the same problem with a Toshiba RGZA 46RV535U purchased 2/2009. My picture gets darker in the center 1/3rd of the screen intermittently. I have removed and reconnected all cable connections on the...
The tubes are horizontal but require disassembling the cover and the inverter
board completelyfrom the chassis. There were 17 of these flourescent tubes stretching the ful length horizontally. They are so fragile.
Jan 01, 2011 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Remote control code for TWF 32" LCD TV wanted for
Hello
There is no other information available about your Apex TV, other than its user manual. In it there are six numbers given and I quotes it here. Check will it help you or not. OK.
[157_158_159_160_161_162]
Nov 05, 2010 | Apex Digital PF3220 32" TV
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Compaq mv540 monitor suddenly can't adjust screen features
Please somebody give a solution as same is experienced by me tooo.
Jan 22, 2010 | Compaq MV 540 15" CRT Monitor
I just purchased an HP w2007 hp monitor. After going through all the suggested start up routines, images are stretched horizontally. I'm using XP home edition with sp 3. My resolution doesn't seem to go...
if it's a wide screen monitor then the monitor is likely doing the stretching and you have to adjust using the monitor controls (either buttons on the monitor itself or it may have come with software as well if you loaded a CD when you first installed).
Mar 31, 2009 | HP W2007 LCD Monitor
Finding a code
What is the model number of the Apex TV you are using this remote for?
The CK5G-C1 remote was supplied only with model AT3208S TV. It will require no code when used with that model. If trying to use it with any other model TV, you can try the other Apex TV codes found in the AT3208s user's manual that can be found in .pdf format at : http://www.apexdigitalinc.com/manual/AT3208S.pdf
Let me know if this helps, or I can be of further help.
In any case, good luck!
Oct 22, 2007 | Apex Digital PF3220 32" TV
Apex Digital PF3220 32" TV Logo
425 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
