Question about HP LaserJet 4300n Printer
Black toner flakes on paper - HP LaserJet 4300n Printer
    Habit-Forming:
  • 64 Answers
This could be a couple of things, easiest thing to try first is to put a different toner cartridge in, something that has already been opened because it would save you from opening a new one. Another thing you can try is sending a cleaning page through the printer to clean off excess toner from the fuser unit. What happens is over time toner builds up on the lower pressure roller of the fuser unit and after being heated and cooled so much the toner starts to flake off on your print outs. Follow these steps to try to clean the lower pressure roller:
To run the cleaning page manually
1.If a duplexer is installed, open the rear output bin.
2.Press check mark(SELECT button) or the MENU button to open the menus.
3.Use (UP ARROW button) or (DOWN ARROW button) to scroll to CONFIGURE DEVICE, and then press
4.Use or to scroll to PRINT QUALITY, and then press the check button
5.Use (UP ARROW button) or (DOWN ARROW button) to scroll to CREATE CLEANING PAGE for the(LJ 4200/4300) or PROCESS CLEANING PAGE if you printer is a(LJ 4250/4350) then press the check mark
6.Follow the instructions on the cleaning page to complete the cleaning process (LJ 4200/4300
only).
7.If a duplexer is installed, close the rear output bin.
This should help clear some of the flaking toner, if not you might have to replace the fuser unit.
Posted on Jul 31, 2009
  • 108 Answers
I would try a new toner cartridge. The fuser might not be heating correctly.
4 Suggested Answers
pdouglasss
  • 125 Answers
SOURCE: ink flakes off envelopes. No problems with sheets of laser paper.
High burnier:
Try these settings.
FUSER MODES
PLAIN
PREPRINTED
LETTERHEAD
TRANSPARENCY
PREPUNCHED
LABELS
BOND
RECYCLED
COLOR
CARDSTOCK>164 G/M2
ROUGH
[Paper Type]=
NORMAL
LOW
HIGH1
HIGH2
ENVELOPE
RESTORE MODES
Use this item to configures the fuser mode associated
with each media type.
Change the fuser mode only if you are experiencing
problems printing on certain types of media. After you
select a type of paper, you can select a fuser mode
that is available for that type. The available selections
might include some or all of the following modes:
NORMAL: Used for most types of paper.
HIGH 1: Used for rough paper.
LOW: Used for transparencies.
HIGH 2: Used for paper that has a special or rough
finish.
The default fuser mode is NORMAL for all print media
types except transparencies (LOW), and rough paper
(HIGH 1).
CAUTION
Do not change the fuser mode for transparencies.
Failure to use the LOW setting while printing
transparencies can result in permanent damage to
the printer and fuser. Always select Transparencies
as the Type in the printer driver and set the tray type
at the printer control panel to TRANSPARENCY.
When selected, RESTORE MODES resets the fuser mode
for each media type back to its default setting.
Hope this helps
Posted on May 24, 2009
  • 127 Answers
SOURCE: Black toner flakes off photo paper
Are you sure that you should be using PHOTO paper in a LASER printer? They usually only use ordinary unglazed paper.
Posted on Dec 01, 2009
  • 48 Answers
SOURCE: The toner flakes off of labels and report card
It sounds like the fuser isn't working properly. If the printer does this with all kinds of paper then you may just have to replace it. However, if it only happens with certain print media then you probably just need to change the printer settings to fit that type of paper. When you select "Print" in any program a window should pop up with the printer options. Look for a button that says "Properties" or "Preferences." In the printer properties/preferences there should be a menu where you can select the paper type and size. Adjust it to what you are using and see if that helps; different types of paper require different treatment. If the paper is glossy, look for a setting for that as well. You can try to access the preferences directly from the printer as well, some printers will let you select paper type, while others only from the computer.
I hope this helps! Good luck!
Posted on Feb 28, 2011
Ink flaking off printed labels
your problem is not good fusing. try with a different fuser.
Apr 10, 2013 | Oki Brand Oki 62433501 C711n Laser...
I have an oki c9650 when I print on cardstock the blacks become bubbly and flake off, but only when printing on cardstock
Set it or computer, whatever you are using to cardstock, or it may be called thick,there are multiple selections depending on the media. Beacuase thick paper requires slower speed and hotter fuseing.
Sep 26, 2012 | OKI C9650HDN Led Printer
Left edge black on hp laserjet printer
Fuser teflon sleeve got damaged, replace it.. (only professionals can do this activity) if its not available go for new fuser assembly..
Jul 31, 2012 | HP "LaserJet P2035n Printer"
It seems like the toner isn't sticking to the paper, or its too thick and flakes off. Is this a saturation problem, paper stock, or maybe a drum or toner issue? If I rub my fingers over the copy it...
The first question is what kind of paper are you using???? Are you using regular copy paper? Have you gotting any error codes? If you are running plain copy paper in the copier and the toner is flaking off, odds are you are having a problem with the fuser unit. Look to see if the toner is fixed on one side of the the paper and not the other side. Odds are you have a problem with the pressure of the two fuser rollers. You may have a cut in the lower fixing roller or a broken ball bearing... Good Luck
Oct 07, 2011 | Canon CLC 1180 Copier
I'm printing on 110 lb card stock and the toner gets crispy..and actually flakes off on the edges and sometimes leaves smears and clumps of black or burnt toner on the paper. It prints fine on 20 lb paper...
could be the fuser but there is a setting for heavy paper or card stock which will slow it down and increase the heat. depends on your model as to where this can be changed.
Jul 27, 2017 | HP Color LaserJet 2600n Printer
My printer is flaking. i am printing a heavy color image on a kyocera fs c8026n. any help?
If by "flaking" you mean that the print is rubbing or flaking off then there are 2 possibilities. If you are using thicker than standard 20lb bond paper then when setting up the print job make sure you are selecting thick paper on your paper setting. This is a common problem if your paper is thicker, shiny or anything other than standard.
The other possibility would be a fuser defect of some type. But that would tend to affect standard black and white prints as well.
Try the thick paper setting as it will slow down the paper speed thru the fuser and will "fix" the toner to the paper better.
Jan 15, 2010 | Kyocera FS-C8026N Laser Printer
Dec 01, 2009 | Ricoh Aficio CL2000N Laser Printer
Dell 3100cn printer trouble
this sounds like you might have 2 problems on you fuser is not getting hot enough to fully fuse the toner to the paper and two your black toner cartridge has been comprimised and needs to be replaced
Oct 16, 2008 | Dell 3100cn Laser Printer
Hp2600n printer
Is the toner fused to the paper, or 'loose', and can be rubbed of easily. Are there 'flakes' of toner, that may or may not be loose?
If the toner is fused, the cartridges are likely to be leaking toner - especially if they are remanufactured - not easy to get right, and even more difficult to get right if 'home refilled'.
Solution to this is replace cartridges, or if these are new return them to supplier as faulty.
If there are 'flakes', it is likely to be the fuser that is contaminated with toner that has ot fused to previous pages - usually as a result of using the wrong type of media, or setting the wrong paper type when printing on thick media.
Fuser can be cleaned, or in extreme cases replaced.
Sep 10, 2008 | HP Color LaserJet 2600n Printer
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
HP LaserJet 4300n Printer Logo
521 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
