Question about Dell OptiPlex SX280 PC Desktop
After upgrading memory, 6 beeps, how to proceed
  • 3 Answers
According to Kingston's web site, the Optiplex SX280 uses DDR2-400 or 533 speed chips of up to 2GB in size, for a total possible maximum of 4 GB. If you've used any other combination or type of chip, its not going to work. Also, make *sure* you've installed the chips correctly; it's easy to do improperly. You start by inserting them at a 45 degree angle, then pressing the high edge down until it clicks into place. Pop them both out if you still have trouble, and install them again. Make sure you've taken all static protection measures.
Posted on Jul 31, 2009
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
6 BEEPS ON DELL MOTHERBOARD REV A00
6 beeps on POST indicates a keyboard error. As virtually all BIOS require the keyboard, it is one error that cannot be bypassed in most BIOS. Is your keyboard connected properly?
Jan 18, 2012 | Computers & Internet
Repeated short beeps, no startup
The beeps are Power On Self Test (POST) beeps. Research them on the web, but here is a quick list.
After you know where the issue lies, you can proceed on those results...
Beep Code Descriptions Document 1 short DRAM refresh failure CH000996 2 short Parity circuit failure CH000607 3 short Base 64K RAM failure CH000996 4 short System timer failure CH000607 5 short Process failure CH000607 6 short Keyboard controller Gate A20 error CH000383 7 short Virtual mode exception error CH000607 8 short Display memory Read/Write test failure CH000607 9 short ROM BIOS checksum failure CH000607 10 short CMOS shutdown Read/Write error CH000239 11 short Cache Memory error CH000607 1 long, 3 short Conventional/Extended memory failure CH000996 1 long, 8 short Display/Retrace test failed CH000607
Dec 06, 2010 | HP Pavilion 734n PC Desktop
I switch it on and it beeps 6 times and stays in standby mode
6 Beeps from what I can gather from the Dell site means a DMA page register read/write failure.
Have you installed any new hardware or upgraded the memory?
Do you have any upgraded components in the system or is it all stock?
Apr 13, 2010 | Dell Dimension 3100 PC Desktop
I have abrand new Dell XPS 8100 with upgraded memory to 8mb and an ATI 5770 graphics card. When I start the computer I get 6 beeps and the PC does not start. Fitted a replacement Graphics card, still the...
Depending on the main board, 6 beeps usually signify's either a RAM issue (like a bad connection or incompatible ram) or an expansion slot issue so check any other cards you may have installed and make sure that The new RAM stick is compatible with the main board.. The main board model code is printed on the main board. Use it to search for audible fault codes, or go to www.upgrading and repairing computers.com and search for the beep codes for the main board on this site. Also, try reseating all the RAM sticks and expansion cards, especially graphics card..make sure you have not dislodged any data connectors and double check everything..
Feb 05, 2010 | Dell XPS 200 PC Desktop
Laptop Beeps on start up 1 long and two short beeps
You've checked the memory board/card, but have you tried using another memory card? The 1 long followed by 2 short beeps indicates that there's a problem with the memory card. Try to remove the memory card, then wipe the gold traces with a dry cloth and put it back in.
If you try replacing the memory card but you get the same problem, then proceed with the video card.
Aug 29, 2009 | HP Pavilion dv9000z Notebook
I have a dell Dimension 8250 and replaced the memory cards with a higher memory. I got a memory error beep code so I replaced the original. I'm still getting the beep code. Any ideas? I was careful...
Please check the following link for complete information on Dimension 8250
http://support.dell.com/support/edocs/systems/dim8250/
Check the technical specification section to see if u bought the correct memory type for this computer to upgrade..if yes then proceed to the adding and replacing parts section to check for the instructions on adding memory.
Jun 27, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
PC will not start
This sounds like a memory error, can you define the beeps. There is a thing called a "beep code" on all motherboards, the website for the motherboard defines what the beeps mean. For example: one long beep followed by two short beeps of continous spaced beeps without a break. chris http://www.motherboardsrus.net
Jun 06, 2009 | Dell Precision Workstation 670 PC Desktop
PC beeping, monitor will not display
we have different sound we can hear in cases of hardware problem, once the video card has loose contact it also beep continously, a beep sound also occurs when the ram(memory card) loose contact, one beep sound when it boot clearly it proceeds as go signal going to operating system. if you are using an upgraded video card remove temporarily and use the on-board from your motherboard. in case that it won't boot and still you hear a beep, beep ,sound then, switch-off the power take out the memory card clean the contact points(bronze color) with pencil eraser, make sure that no remaining residues of eraser remained before you install to the slot. i hope that this solves your problem
Dec 01, 2007 | Computers & Internet
My nokia needs to reprogram HELP plzzzzzzz!
*#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration.
*#7370# - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead.
turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up).
Aug 17, 2007 | Nokia 6288 Cellular Phone
Dell OptiPlex SX280 PC Desktop Logo
150 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
