Question about HP Officejet 7210 All-In-One InkJet Printer
When i print it, it sends the job to the printer but when i open print jobs it says error
  • 108 Answers
Try deleting the print driver. Then reinstall the print driver.
Posted on Jul 31, 2009
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
ERROR 016-720 FOR DELL
The problem correspondent to this error code is: "Error relating to PCL emulation problems occurs."
The solution is: · Press the "Return" buttonto clear the message, cancel the current print job, and conduct the next print job, if any. Press Cancel to cancel the print job.
Mar 30, 2010 | Dell 3100cn Laser Printer
HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Dec 14, 2009 | HP Hewlett Packard LaserJet P1005 Printer
General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
How do I turn on my RAM disk? (Dell 3100cn)
the print job may be too large for the available printer memory.
Your choices are one of the following:
Press to clear the message, cancel the current print job, and conduct the next print job, if any.
· Press Cancel to cancel the current print job.
· Press Menu to open the Stored Print and delete the current job.
To avoid this error in the future, do the following:
· Reduce the number of print pages such as splitting the print data.
· Increase free memory space by deleting unnecessary data in the RAM disk.
As for the RAM disk:
When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory.
Whenyou are ready to print the job, you must go to the printer and use theoperator panel menus to identify which job in the memory you want toprint. You can use this function to print a confidential job (SecurePrint), or verify one copy before printing additional copies (ProofPrint).
NOTE: The printer holds the job until you delete it byusing the operator panel or you turn off the printer. (This is the RAMdisk)
NOTE: Print and Hold functions require a minimum of 320 MBavailable printer memory. Also, you need to configure the RAM disksettings on either the OPERATOR PANEL OR THE PRINTER DRIVER.
NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs.
RAM disk is an option for that printer, but most users do not have thatoption, and if you accessed the menu for the 3100 on most of themachines in use you would receive that same error.
Although the printer itself shows " ready to print", this does not meanthat your computer is communicating with the printer. In Fact, thatmessage would show up even if you did not have it attached to anycomputer, as long as it was turned on and passed the self test.
More then likely the problem lies within the computer, NOT the printer.
To test the printers functionality, try printing a menu item, from the"reports" menu. Select either the printer settings, or the PCL Fontsreport. When selected, the printer should print which ever report youselected.
One thing you may want to check is to see if there are any print jobs "locked up " in the print spooler on your computer, and also make surethat the printer is not set to "work offline".
To do this, open the control panel, go to your "printers" folder, then double click on your printer.
This will open up the printer information for that printer. If there are any jobs in the print queue, they will show up here.
if there are any print jobs stacked up, usually it is the top job thathad a problem and is "stuck". This will prevent any job sent after thatto be held, pending release of that one.
single click the top job and either restart the job, or delete it.
Also, make sure that the printer is not set to work offline by clickingon "printer" from the menu and ensure that work offline is not checked.
Take this link and print it out. It will help you later when you get "other" error messages.
http://support.dell.com/support/edocs/sy...
Sep 18, 2009 | Dell Office Equipment & Supplies
I have a lexmark t644 printer and have an error code of 900.44 any ideas on how to fix this
  1. If the printer is currently displaying a 900 RIP Software error, power off the printer and leave it powered off for 20 seconds or more. Doing this will clear the printer's memory.
  2. While the printer is off, clear any pending print jobs from the computer or the network queue. This will prevent any corrupted print jobs from being sent to the printer again when it is powered back on.
  3. Power the printer back on.
  4. If the printer goes to the Ready status, try printing again.
  5. If the 900 RIP Software error returns when the printer is powered up or when you try to print, there is a problem with either the printer, the communication cable connecting the printer to the computer, or with the print job itself. Follow the directions below to check each of these components.
    • If the error appears every time you power on the printer, regardless of whether you send a print job or not, the likely source of the problem is the printer or an option installed on the printer.
    • If the error appears only when you send print jobs to the printer, the likely source of the problem is the computer, a setting on the printer, or one of the communication cables.
Nov 17, 2008 | Lexmark T644 Laser Printer
Ram disk
Stangowner, In this case, the print job is too large for the available printer memory. Your choices are one of the following: Press to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the current print job. · Press Menu to open the Stored Print and delete the current job. To avoid this error in the future, do the following: · Reduce the number of print pages such as splitting the print data. · Increase free memory space by deleting unnecessary data in the RAM disk. As for the RAM disk: When you send a job to the printer, you can specify in the driver that you want the printer to hold the job in memory. When you are ready to print the job, you must go to the printer and use the operator panel menus to identify which job in the memory you want to print. You can use this function to print a confidential job (Secure Print), or verify one copy before printing additional copies (Proof Print). NOTE: The printer holds the job until you delete it by using the operator panel or you turn off the printer. (This is the RAM disk) NOTE: Print and Hold functions require a minimum of 320 MB available printer memory. Also, you need to configure the RAM disk settings on either the OPERATOR PANEL OR THE PRINTER DRIVER. NOTE: Depending on the documents, its job may be too big for the available memory. In this case, an error occurs. Take this link and print it out. It will help you later when you get "other" error messages. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section19.html And here's a link for more "operational" situations. http://support.dell.com/support/edocs/systems/3100cn/en/UG/section16.html#1087088 ZT3000 "Beta tester of "0"s and "1's"
Aug 21, 2007 | Dell 3100cn Laser Printer
Installed drivers and set up new unit per instructions,unit will not scan or print from any user
open the nprinter folder and confirm that your preinter is set as the default printer,try and print a test page,then send your printing jobs,good luck. eyo7 eyoifiok2005@yahoo.com
Mar 30, 2007 | Lexmark X7350 All-In-One InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
