The chargeing picture shows then keeps bliking will not charge or turn on
Not sure of your Brand and Model. BUT in most electronic devices IF indicator shows charging BUT wont charge the BATTERY/(s) are not holding charge and needs replacing.
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
SOURCE: charging problem....
You might have a "bad" song? Try wipping the songs off and resyncing youre player. Also, for the charging problem. Are you charging it through your computer? I've found that these players charge ALOT better through an AC outlet. I hope this helps.
SOURCE: 2007 Corolla battery not keeping charge
There is an electrical problem. Get someone to scan the vehicle.
You might have to replace the alternator and the battery.
Sorry
rate this please
SOURCE: battery will not charge compaq presario v5000
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Testimonial: "good advice"
SOURCE: Wont charge or keep a charge
First off, a google search will show you several companies out there that will replace the cells in your existing battery for around $70. Not bad. However, you mentioned that positioning of the plug can get it to work. The solder joints can become broken from the board, and the small plug in jack will get loose after a year or two of plugging in to it.
You can get a replacement plug at fry's electronics, or many online stores. If you need a service manual, or driver disk set, you can get them at mpcdrivers.com
SOURCE: I have two ipod video's
Hello.
Try charging your A1059 with a Firewire cable.
Hope this helps.
