Question about Tomtom GO 720 GPS Receiver
Vehicle is not keeping up and then loses the map
    Brigadier General:
  • 4,090 Answers
Low battery power
poor signal
attach an external antenna
Posted on Aug 01, 2009
I have code po107 after clearing it it keeps coming back
code p0107 refers to manifold absolute pressure(MAP) sensor / barometric pressure (BARO) sensor --low input===causes --wiring short to ground --MAP sensor---BARO sensor ---ECM
check the wiring and connections to the MAP sensor
replace the MAP sensor
clear codes and run to see it the code comes back
if it does then replace the BARO sensor
Oct 23, 2015 | Thule 2002 Chevy S10 Pickup - Crew cab -...
Idle issues
Clean & or replace MAP sensor. A clean air filter is an assumption
Jun 24, 2013 | 2002 Chevy Impala - 3.8L V6 - Electric...
GPS indicating check map dsc error
This is a common navigation radio issue on this vehicle. The message "Map DVD read error" comes on randomly.... sometimes it works, sometimes it doesn't. Make sure your Map DVD is clean and without fingerprints or scratches first. If it the disc is okay, the issue, unfortunately, is within the radio itself. The only correction I've seen for this problem is to replace the radio itself. Also note, that if the radio is replaced, it will have to be reprogrammed by a GM dealer to correctly set up your vehicle's options and learn the vehicle's VIN so the radio will unlock.
Mar 19, 2013 | 2007 GMC Acadia SLE
1990 Buick Silouete loses power when accelerating, as engine warms it gets worse. Changed filter and had gas tank cleaned out recently did not solve the problem. It drives ok at normal speeds, it spudders...
You are a 1990 Oldsmobile sihouette with a 3.1 these vehicle are speed density in other word you are equipt with a MAP (manifold air pressure) when this sensor fails you loose the ability to accelerate or hesitate as you accelerate make sure the vacuum hose is connected to it and it is no leaking vacuum if the hose is okay and it is electrically connected correctly your fix is to replace the MAP sensor
Aug 05, 2011 | 1990 Oldsmobile Silhouette
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 | Garmin GPS
When I crank the vehicle I have to keep the throttle open I checked the ECU for trouble codes it showed a problem with the MAP sensor voltage too high I replaced the the MAP sensor then trouble code showed...
Need to check the wiring from map sensor to control module and make sure you got correct map sensor also if o2 sensors are giving incorrect reading can affect this
Nov 12, 2010 | 1993 Chevrolet C3500
I am going to NZ for 10 days and would like some up to date maps for my F10 Navman, How do I download them on the cheap; and Will I lose the current australian maps that I have loaded
I don't know if there's a cheap way to download maps, but your original maps should not 'disappear' in the update as long as you have enough memory in your unit.
Safer way to do this is to load the additional maps on memory card and use that (I take it that you're not taking the trip every week or so, so the maps don't need to be constantly in the device. On the other hand, you can keep the card in to keep the slot from getting dirty.)
Nov 29, 2009 | GPS
Formatted on WINxp
You may be in luck
go to this webpage and download webupdater
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
keep your fingers crossed. basically that is an external hard drive... when you format it.. you erase everything... apparently that has partitions in it as you didn't lose everything tho i suspect you did lose the maps
Robert
Jan 08, 2009 | Garmin n?vi 265WT Car GPS Receiver
Tomtom GO 720 GPS Receiver Logo
65 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
