Question about Kenwood KD-291RC Turntable
Turntable does not turn
When I bring the needle to play the record the turntable does not turn. it makes the noise so somethings happening but its just doesnt go round!! Help I have spent way too much on LPs today for this thing not to work!!
    President:
  • 2,976 Answers
Remove the 'E' clip at the center of the turntable. Cup your hand around it and pop it off with a screwdriver. It can fly across the room. Clean the inside rim of the turntable, the rubber drive wheel and the motor post. If you can find "Vita Drive" that's best but Radio Shack will have something comparable. Make sure there is NO film left on any surfaces. At WORST, you will have to replace the drive wheel.
Posted on Jul 31, 2009
I have an old record player. It was made in the 80's according to my mom. I have recently started to use it( it hasn't been used since 86). With the exception of 45s, the record player will only play side...
I must say I have never come upon a record deck that will only play one side of a good condition record!
The only action I can suggest is to replace the belt if it's a belt driven deck. Please make a note of how it fits before removing the belt. But why any record deck would treat a new record any different on one side than the other will be a mystery to any good engineer.
The only exception would be if the deck played one side good then played up on every other record. Till it's switched off for a while, then repeats this action.
The cause of this fault would be a part overheating the longer the deck is left on. When you stop it to turn over, the system fails. This is however more likely to happen on a direct drive turntable, not a belt driven one.
Aug 24, 2014 | Audio Players & Recorders
I have a JVC turntable and an old Sansui reciever. Last night I was playing a record, and it stopped playing out of one speaker, and makes a loud buzzing noise. However, when I push the Mono button
You should check the connections to the turntable, it sounds like it might be feedback hum, caused by a wire touching or something like that. Don't forget to check the connections to the cartridge too.
Feb 09, 2014 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Just inherited an old califone 1010av. It turns on, but when I put the record on the turntable and bring the needle down, there is no sound and the arm slides to the center of the record very quickly. I...
SOUNDS LIKE NEELDE BROKEN.TO TELL PUT FINGER UNDER NEEDLE PULL BACK FINGER GENTLEY AND YOU SHOULD FEEL A POINT ON THE END OF THE NEEDLE.IF NOT OR UNSURE SEE IF YOU CAN SEE THE END OF THE NEEDLE THERE SOULD BE A SAFIRE OR DIOMOND IN THE END OF IT THAT SITS ON THE RECORD IF NONE IS SEEN REPLACE NEEDLE.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Califone International 1010AV Turntable
When playing a record the needle gets stuck at the same place, near the end f the record evevry time. Does not matter what record. Happens with all of them.
I don't know the AT PL50 but I had a similar problem with another make of turntable.
The problem was caused by the rear end of the pick-up arm hitting the side of the perspex cover. The solution was a simple one - leave the lid in the raised position or lift the cover right off when playing records.
Jan 30, 2011 | Audio Technica AT-PL50 Turntable
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Kenwood KD-291RC Turntable Logo
209 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
