Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Mower Deck not level
I have a Toro Wheel Horse 17-44, I removed the deck to sharpen blades. I reattached exactly how it was before and now the deck is not level, side to side. How do I level this back to get a flat cut?
  • 72 Answers
There is a geared bolt at the deck suspension un lock it and rotate it will raise and lower the deck
Posted on Aug 04, 2009
Belt diagram install
seems like everyone does but no one knows there model number... darn
Aug 25, 2014 | Toro 3 Standard Blades For Wheel Horse 50"...
I have had the mower for about a year. Since I have owned the mower it leaves a trail of grass beneath the center of the deck. I have taken it to a toro dealer to check out the blades and deck and they...
Sharpen the blades,very sharp,and lift the deck one notch from where you normally cut.Some times the blades will get dinged,or the ends of the blades will dull.
May 17, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Toro wheel horse rider recycler 8hp-25inch cut model#56132 how to remove mower deck
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual.
Apr 30, 2011 | Toro Garden
WHAT CONFIGURATION DOES BELT GO BACK ON TORO RIDE ON. TORO WHEEL HORSE 15-44 HXL
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Jan 15, 2011 | Toro 3 Blade Set For Wheel Horse 42" Deck...
Ajusting mower deck on husqvarva lawntractor been trying to make it level,has two cutting blades and this mower is not very old bought it last summer,
I think the two bladed units are 42" and down in size. The 48" are 3 bladed units. There are instructions in the manual for leveling the cut. If you do not have a manual, look on line for a manual, google it. First step is to get the mower sitting on a level piece of concrete. That way you know which corner needs to be raised or lowered. Then make sure your blades are mounted correctly. Usually you can see the adjusters, threaded bolts and nuts, or pins. Usually the deck comes level and gets **** up by someone taking the deck off to swap or sharpen blades.
Mar 06, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Mower leaves uncut strips between blades.
measure blades on a level surface.place each blade side to side and see if their is a difference,all measurements should be the same,if not you have a bent deck or a spindle that is bent.
Jun 28, 2009 | Toro Lawn Mower With Toro Power Tools
Replacement blade position.
The blades have such a close tolerance tip to tip on a V belt deck that it makes no difference where they are positioned, On a 3 blade deck the center spindle is forward of the two outer spindles. So for that reason you still get a quality cut. Most all commercial units use a V belt and have a good quality cut.
Some john deere mowers have a timing belt with cogs like a car and their blades have to be in time
90 degrees perpindicular to each other and locked down and if you strike something then the timing will be off and your back working on your mower instead of cutting grass,and the belts are twice as expensive than a v belt.
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Dual blade mower leaves uncut strips between blades.
Had same uneven mowing problem with new Toro Z4200 XTR mower. Problem was one side of the U-shaped rear deck hanger rod had popped out of its chassis mount (did hit something with mowing deck). Removed hanger chassis mount & its bolt. Put end of U-shaped rear deck hanger rod back in the chassis mount and remounted hanger chassis mount & its bolt. Z4200 now cuts lawn evenly again.
Jan 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
625 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
