Question about Luhr Jensen Big Chief 9890
Big Chief smoker trips 20 amp GFCI
Element starts to heat up then the 20 amp GFCI trips. Any ideas why?The unit is several years old and has been in storage for about 2 yrs.
  • 4 more comments
  • hbg1 Jul 31, 2009
    Wow - thanks for the quick response.
    I tried it on three different 20 amp circuits, all of which I made sure had no other loads attached. All three tripped within 30 seconds of plugging in. Cord has three prong grounded type.
  • hbg1 Jul 31, 2009
    Plugged into three different 20 amp circuits all of which had no other loads. Cord has three prong grounded connectors.
  • hbg1 Jul 31, 2009
  • hbg1 Jul 31, 2009
  • hbg1 Jul 31, 2009
  • Jeremy Spatrisano May 11, 2010
    Is this being run on a dedicated 20 amp circuit, or are there other appliances also being run on this circuit?
  • 57 Answers
Try to use another out let and see if it is the GFI outlet first if it trip the new outlet then you know it the grill and not the outlet
Posted on Aug 25, 2009
I need a new electric heating element for my Little Chief smoker
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=Little+chief+replacement+element&rh=n%3A3375251%2Ck%3ALittle+chief+replacement+element Here is one source....
Jan 15, 2013 | Grilling
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My smoker keeps tripping my ground fault receptacle. I plugged in other items and i had no problem with tripping the ground fault. I also had to change the female connector going to the heating element.
If nothing else is tripping your GFCI, then there is a short somewhere in the wiring of the smoker. Check the female connector you had to replace, as well as that particular to see if you can detect any melting of the insulation or a bad connection of the other end.
Typically, electric smokers use high heat resistor wiring. So, something in the wiring is not like it should be. Or it may be the heating element itself. If it's still under warranty contact the manufactirer.
Feb 06, 2011 | Masterbuilt 20070106 Electric Smoker
I have experienced deforming of the plastic/rubber outer portion of the LEFT socket of the power cord where it connects to the heating element of my Big Chief smoker. I have two smokers and it has...
Sorry to read about your problem, I hope this helps you out.
It is not uncommon, for plugs that connect direct to heating elements. The left socket is the high resistance side, and heat is generated, so the socket deforms. The cord is made in china, and they are cheap.
The permanent fix, would be to hard-wire the the heat element wiring to a new style heavy duty cord, rated for 20 amps
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Luhr Jensen Big Chief 9890
My electric smoker keeps tripping breakers
My Brinkmann 810-7080-4 Gourmet Electric Smoker was tripping my GFI after it sat for the winter. Would heat for about 3 minutes then trip the GFI. would keep tripping GFI until it cooled down and once again would trip after about 3 minutes.
--SOLVED: took 00 steel wool and olive oil to the heating element and removed what looked like a green fungus. Element is working fine now, not tripping the GFI and will run a full four hours for smoking!
Hope this helps save someone some money in purchasing a new heating element ($40).
Nov 26, 2009 | Brinkmann Smoke' n Grill Electric Double...
I have a little chief 9800 top load smoker and lost the heating element in a move. There are two elements available, a 7.5" and an 8.5", but I'm not sure which size my smoker takes. Is there any way to...
The #4 Little Chief element is 7 inches and more importantly is 250 watts, this is the correct wattage for ALL Little Chief Smokers newer than about 15 - 20 years old.
The #5 Little Chief element is 8.5 inches and is also 250W but is for newer models before 2006.
Look at www.smokehouseproducts.com for clarification & best fit.
For very, very old models (20+) there is a ceramic disk (175W) that heats the chip pan and is hard to find and expensive, a person would be better off finding a new one on sale at the big box boys store
Jul 07, 2009 | Luhr Jensen Little Chief 9800
My little chief smoker never got the fish I was smoking to 140 deg.I had this unit smoking for two & half hrs. is this normal?
How old is the smoker? Is the heat element old, weak (maybe needs replacing?) Did you save the cardboard box the smoker unit comes in and place it over the smoker for the actual smoking process? This is recommended by the manufacturer and keeps the smoke and heat in, and gets you up to temperature. see also www.smokehouseproducts.com
Jul 02, 2009 | Luhr Jensen Little Chief 9800
Lil Chief Smoker trips GFI plug
There is a short somewhere in the unit. Return it ASAP!
Jun 25, 2009 | Luhr Jensen Little Chief 9800
Replacement Parts - Lil Chief
Try www.smokehouseproducts.com or any Cabela's or Sportman's Whorehouse, I mean Warehouse or any big box sporting goods store in general. The heating element is a hard one because it's probably the old style ceramic disk. We have two like that. They run on 175 Watts instead of the newer 250W using the "O" shape elements. They're $29.99 + s/h, we want to try to convert ours to the newer 'O' shape if possible. The elements are around $12.00 at Wally World. Best of luck!
Jan 31, 2009 | Luhr Jensen Little Chief 9800
Grilling Logo
946 people viewed this question
Top Luhr Jensen Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Luhr Jensen Grilling Expert? Answer questions, earn points and help others
