Over filling the machine intermittantly overfills. I mean completely full over the top of the tube. the coldw ater won't shut off.
    President:
  • 1,776 Answers
I would look at a faulty water level switch. This is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, pressure increases on the air in the tube and when it reaches a certain level, it activates the switch to turn off the water and signals the timer to start the agitate cycle. Look for any obstructions in the tube and clean out if there is. The switch can be tested using a multimeter or ohm meter to see if it has continuity. If it does not, the switch is defective and will need replaced. Hope this helped and best wishes.
Posted on Jul 31, 2009
My washer will not stop filling. it will continue to fill and overflow. What do I do?
Hello there:
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 03, 2010 | GE WJRR4170E Top Load Washer
Does not stop filling with water
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Feb 01, 2010 | Hotpoint VBXR1090D Top Load Washer
Roper washing machine will only run one load every 12 hours!!
Jan 21, 2010 | Washing Machines
Kenmore 70 series , overfill water dose not stop at set fill levels
Jan 16, 2010 | Washing Machines
Cold water does not shut off when washer fills - will over flow - hot water will shut off when washer is full ...
Jan 03, 2010 | Kenmore Washing Machines
A machine that overfills or underfills can often have a faulty water level switch. It's a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level, it activates the switch to shut off the water. Make sure there is no damage to or obstruction in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Washing Machines
Top load washer does not stop filling and over flows
TOP LOAD WASHERS HAVE A PRESSURE SWITCH UNDER THE TOP WITH A TUBE THAT GOES TO THE CONTROLS FOR THE WATER LEVELf89272d.jpg
Aug 11, 2009 | Washing Machines
Flooding and overfilling
Hi
Please accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 24, 2009 | Amana ALW480DA Top Load Washer
Machine over filling even when set on min. simpson enduro 701
When the machine is overfilling , it means that there is a problem with the inlet valve (valve not closing) or with the water level switch, that should turn off the valve when water reaches level.
See the suggestion from It's overfilling at repairclinic:
Water-inlet valve
Water-level switch
Oct 06, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
