Question about Kenmore 75085 Air Conditioner
Can the ac unit be recharged i have the 580.72006 or 580.72126
Can ac unit be recharged?
    Scholar:
  • 117 Answers
A/c units can indeed be recharged.You need to determine if the gas leaked out. More than likely has r22 in it. The unit will have to be removed from the case to access the low side of the compressor where the charging port will have to be placed. however ,unless you have a section 609 epa certification, you will not be able to purchase the freon. You will also need a vacuum pump, refrigerant recovery device and gages. Better to let a certified technition do it. Hope this helps
Posted on Jul 31, 2009
The aircon system on my B Class has been recharged but after about two months the cold air is not blowing.
recharged it but didn't fix the leak
take it to an accredited ac specialist shop for a system check and fix
ac units do not need recharging unless there is a leak
Oct 27, 2016 | Cars & Trucks
Need Recharge?
Make sure your AC is set to cool and not dehumidify . If yes try lowering the temperature , if still no cooling then yes you probably nee to recharge
May 24, 2013 | Panasonic CW-XC143EU Air Conditioner
What is the polarity of the jac/mic so I can charge rechargeable batteries by ACDC adaptor
On you're AC adapter unit, there should, if it's a good one, have a switch with a + & - signs indicating the polarity you require to use.
Further to this, does your radio have an AC recharge point. Some of these units don't have this capability, but in your case it may.
This is usually found on the side of the radio.
If there is no such point, then what you need is to buy rechargeable batteries with the appropriate charger, you can't just use any charger for these batteries, else you'll damage them.
I hope this helps you.
Best regards,
Peter
Jan 27, 2013 | Columbia Telecommunications Group...
2007 dodge nitro not blowing cold air
The AC compressor may need recharged, or repaired / replaced. A lot of times what happens is through the winter AC units aren't ran so the seals recieve no oil and dry out letting coolant escape. Sometimes you can get lucky and a recharge (which contains oil essential for your seals) will do it - if they are too dry however, you will need a new compressor. You can have your AC unit recharged at nearly any dealership except in the state of California. Hope this helps.
Mar 27, 2012 | 2007 Dodge Nitro R/T New Cars
How do you put freon in a whirlpool window unit
you will need a AC Tech to first 'repair' the leak and then to 'recharge' the system. Also, the Tech may have to 'weld in' service valves on the unit if it does not have them - which most window units do not have.
Note: unless you've had a 'leak' you'll never need to recharge the system. I would 'be sure' you needed to recharge the unit before having it recharged.
Sounds like you might really need to have a AC Tech look at the unit before you do anything.
Aug 04, 2011 | Whirlpool Electronic Window Air...
Ac window unit, can it be recharge?
Hello, yes the Ac can be recharged however you will need to install a piercing valve on the low side of the system in order to recharge the unit.
May 05, 2011 | Heating & Cooling
Can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Recharge freon ge heat & ac unit
Jump out the control, make the machine run constantly and recharge it.
Apr 21, 2009 | GE Heating & Cooling
Window Air Conditioner
Second try....
Any unit can be recharged, however, its not cost effective to repair most window units unless they are under warranty.
Sep 06, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Air conditioning
some parts stores sell recharge cans of 134a. most ppl believe that the ac unit in a car naturally loses charge over time. big myth an ac unit is sealed nothing can get in or out with out there being a leak. before you waist time recharging it yourself find the leak either a loose fitting or a bad O-ring in one of the snap fittings i highly recommend taking it to a ac technician so that it can be properly evacuated to remove any moisture or other contaminants that may be in the system.
Aug 20, 2008 | 1999 Dodge Ram
Kenmore 75085 Air Conditioner Logo
411 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
