Question about Kenmore 3.5 cu. ft. King Size Capacity Top Load Washer
No cold water only hot water will filling
Our Kenmore washer is still under warranty. When filling the machine with water there is no cold water only hot water.-checked screens on both ends of the cold water hose and the hoses are clear.
  • mike elliott May 21, 2014
    If the water inlet valve is bad you can verify this by switching the wires on the solenoids, if you only have cold water after switching, you know the solenoid is bad if not then the timer is bad. Only thing possible is bad or disconnected wire, stopped up screen, bad solenoid or bad timer.
    President:
  • 1,776 Answers
The water inlet valve solenoid is probably faulty. You can check it using a multimeter or ohm meter for continuity to see if it is faulty. The solenoid is most likely faulty on the cold water side. Here is a picture of the inlet valve solenoid assembly. Hope this helped and best wishes.
Posted on Jul 31, 2009
Is any body know what type of plastic i used for washing machine inlet valve?
Posted on Feb 02, 2010
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Hi I have a problem with my Kenmore washing machine,in particular I can not use hot water anymore. When I use my washing machine hot water does not stop at set water filling level (law, medium,high)...
Please post the model number for your washer. It sounds like your hot water valve has failed and is not closing. Unplug your washer's power cord and turn the hot water spigot that comes out of the wall on. If you still get water filling your washing machine, it's definitely the washer's valve and you will need to install a new set (hot and cold valves are both part of the same assembly).
Mar 11, 2011 | Kenmore Washing Machines
Cold and hot water are mixed up.
I just purchased the same model and have the same problem. Call Sears and have a repairmen sent while still under warranty. The water temperature sensors needed to be replaced in my washer.
Feb 06, 2010 | Kenmore KSM100 Stand Mixer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Kenmore HE 3.8 washer has only hot water even with cold settings
If the washer fills very slowly when you have it on a cold setting the cold water may be shut off behind you washer or possibly the hot and cold are switched. if that is not the problem then you have a relay problem with the machines electrical system.
Jul 01, 2009 | Kenmore Washing Machines
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Washing Machines Logo
195 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
