Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Ws55513... blinking light
I have a ws 55513. I replaced the capacitors and still the blinking green light. Any ideas?
  • 64 Answers
No...but you may not have replaced all of them (there are 8 total in a "repair kit")
Posted on Aug 01, 2009
Need instructions of 55"t.v model ws55513 d m board with capacitors
  • Try going To http;/www.techlore.com/24711/Mitsubishi-Blinking-green-light-repair-procedure.... It Suppose Load up about Nine Pages of Stuff on how to fix the (DM Module Board) If you Can't Fine The 1000 uf 35 wvdc Operating temperature 105 C: Electrolytic capacitor Try The Radio Shack one It Rated At 40 To+ 85 C It Will Work If You Can 'Fine The Other one !05 Deg. C Type -----Check Out This One Too 78 Pages (http://www.techlore.com/x/article/24711/Mitsubishi-Blinking -Green-Light-Repair-Procedures.(Ps) It Want Hurt To check The Ones In the power supply area,other Area .Too You might Have Change them All If You Have All The 1000 uf Check If they Showing Under Less Then The are Rated at Then It Want Hurt To Them All
May 27, 2014 | Mitsubishi WS-55513 55" Rear Projection...
Blinking Light Problem on Ws-55513
If bad capacitors are the problem then replacing them will involve soldering.
If the problem is something else less visible then fault finding will be difficult without the proper service manual.
http://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-55513-service-manual/prod_37.html
This will show the correct disassembly and test procedures.
Good luck.
Oct 20, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws55513 Blinking light -capacitors changed
check the resistor chips on the bottom side of the circuit board solderd directly to the traces one or more may be open.
Nov 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws55513 Blinking green light- replaced capactitors
Hi again,
It would seem that you posted twice. My compliments on accomplishing the replacement of the 4 1000 uF/16V capacitors on the DM board.
Toyour concern, the blinking is still there even after having replacedthe caps, a friendly reminder, the capacitors are polarized, there arespecific +/-. Additionally, you may have to check the pico fuses. Theywould be on the backside of the DM board and would be very close nearto the solder points of the 4 caps. They are marked FB900, FB901 andFB902. Rating would be 125V 4amp. Possible source maybe here.
Justa start, do postback how things turned up or should you need additionalinformation. Good luck and Thank you for using FixYa.
http://www.chrisandnat.com/projects/BlinkingTV/Blink.htm
Sep 02, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Won't turn on WS 55513
Check the pico fuses on the back of the circuit. see if one has blown that seems to be another symptom on the WS models. They are little tiny ceramic fuses soldered to the runners themselves. hope this helps.
Jan 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Nothing works
You will need the DM module repaired....requires replacing
four 1000mf 16v 105 degree capacitors with a bit higher
voltage = 25v or 35v.....if too tall, lay them over 90 degrees on
to board.....there are many entries concerning DM module
rebuild...........if you need further assist,let me know...T.
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
