Question about Compucessory Office Equipment & Supplies
Was shreeding paper and it stopped? cleand it. thought it might be over heated. compucessery mo.#ccs60061. Its new. Thanks Mark
  • 55 Answers
Some of the new shredders do that so you should get a shredder that has a warrenty so if this happens again you dont have to worry about haveing to buying or fixing the shredder because when you try to fix these type of machines you ether end up just causing the machine to be comepletly unusable or it works of a little wile and u have to try to fix it again instead i advise you buy a replacement Fellowes® PS-79Ci doesnt jam and can dice 12 sheets of paper
hope this helps
Posted on Jul 31, 2009
I HAVE A BRAND NEW DEWALT D55168...I'VE HAD IT ABOUT 3 MO.S... I WAS USING IT INSIDE ABOUT 2 MO.S AGO AND IT SIMPLY STOPPED... I HAVEN'T HAD TIME TO DEAL WITH IT, AND I DIDN'T FILL OUT WARRANTY...
If you bought it at HD return it for a new one. If not you will need to use a meter and check power from receptacle to on/off switch to pressure switch., Check motor winding. If all else fails call Dewalt and they will help you.dfffd6xqamff+a17gofmrmxewaaaaaelftksuqmccaa==
Nov 30, 2017 | Dewalt D55168 1.8 HP Wheeled Portable...
Delayed start
Unlikely if it was working normally before you cleaned it. You have most likely disconnected someething
Dec 14, 2012 | Casio Parts Cash Register PC Desktop
The shredder will not automatically shut off. After you have finished feeding the documents to be shreeded the machine contunues to run and you must manuall shut it off.
depending on what you have available, either a damp paper towel or alcohol wipe, or compressed air will work to clean the sensor eye located top at the center of the paper feed opening, you should see a little dot wipe, or spray these out well, then turn the machine off and back on again.
built up dust from the paper causes the sensor to keep registering that there is paper coming in hence it won't stop on its own.
Apr 05, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
I tried to put too many sheets through the shredder at one time and it stopped working. I tried switching it to reverse, but it wouldn't move. I unplugged the shredder, pulled out the sheets, and cleared...
Try removing the shredder and unscrew it from the base. Using a small screwdriver, advance the teeth one row at a time to remove unseen clots of paper around the wheel, then brush with graphite for lubrication.
Aug 16, 2010 | Compucessory CCS60061 Shredder
HSM AMA 125HS-6 Starts to shreed and abuptly stops. Red light comes on next to a circl symbol.
Thickness of papers is too much. Feed only 1-2 pages at a time.
To clear, pull paper back out. Run reverse, then forward, then feed 1 page at a time using a clean edge.
Sep 13, 2009 | Office Equipment & Supplies
Flashing triangular light with the exclamation mark inside it.
Clear the printer queue on the computer (double-click the printer icon in the tray or in the Printers and Faxes folder and cancel all documents listed). Then power off the printer and disconnect the power - remove the paper from the paper tray until you have the printer memory cleared as to not waste paper.
Jan 22, 2009 | HP LaserJet 1320 Printer
1989 transmission lock up hesitation
We took the car to a mechanic and he cleanded the throttle body and put in new plug wires! My husband had not thought of that! thanks....
Aug 02, 2008 | 1989 Buick Park Avenue
Slow turn, hot food
underneath the deck is a geared motor that turns the platter. check for non lubricated bearings or slipping gears.
Aug 22, 2007 | GE JVM1440 Microwave Oven
402 people viewed this question
Top Compucessory Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Compucessory Office Equipment and Supply Expert? Answer questions, earn points and help others
