Question about HP LaserJet 1000 Printer
Remove side panel
I cannot see how to remove the LH side panel to refix the switch which is operated by the printer cover.
  • 82 Answers
Re: remove side panel
It is a bolt cowered by a white label behind, then put a bit flat screwdriver from the bottom..., done.
Posted on Dec 28, 2007
0 characters
3 Points
Samsung transfer belt color
First Take out the transfer belt out again and refix and put the connectors properly.
Next check the driver settings.
Check the toners are present and working by installing a samsung smart panel software.
then u print .
If the same thing exists. take assistance of service center. it may be HVPS problem.
Mar 25, 2012 | Samsung CLX-3175FW Multifunction Laser...
Power switch doesn't work
>Switch off the power, observe while powering on any blink on operation panel? if not check power adapter,>Open upper cover(remove 4 screws)check operational panel connector re-fix it,>open operation panel, check power button contacts dirty? clean it, check rubbed pad carbon contacts found faulty, replace rubber pad.
Oct 05, 2011 | HP PSC 1210 All-In-One InkJet Printer
I need to reset the memory of a HP Designjet 500ps. Can someone help me ?
The memory is located on the formatter assembly, which is in the rear of the plotter, LH side by the JetDirect Card. (behind a removeable cover beside the paper roll)
Feb 23, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
I have a hp psc 2100 and it will not print. I have rebooted, uninstalled, restalled and when completed, the printer either reads "scanner failure, turn off, turn back on" or "printer test...
Hello,your scaner seems dirty,first open the control pannel by pull out the cover then you will find some slots after removing the cover you will find a mark push them & push the pannel to down ward remove the cable from connectors.
open all the screws remove the cover over the glass & over from scanner assembly,take out the scanner assembly from printer .
After removing the scaner *** open them & clean inside ,reflecting mirrors & lence by a soft cotton refix them as open,
Note one thing the home position sencor situated as white strip insidephase of flatebed scaner clean also then .
Refix the unit as open carefully your problem will be resolved 100% ,altough it persists then replace the flatbed scaner.
Pls comment whether it works or not ....................regards... jitendra
Dec 18, 2010 | HP PSC 2110 All-In-One InkJet Printer
Start button on 5055 canon copier seen to be stuck; what can be done to reset it
hi just remove the panel and remove the switching pcb just remove the start button and clean with hot water and dry it then refix the pcb and panel its done.
May 14, 2010 | Canon PC-920 Black and White Copier
How do I replace the display panel
1. Remove the upper front cover.
2. Gently press the three operator panel lens cover retaining tabs (A) and remove the lens cover. The button membrane is free to remove from the assembly.
3. Disconnect the operator panel cable and remove the operator panel board.
Good luck, Gerrit Jan
Oct 28, 2009 | Lexmark Optra S 1855 Laser Printer
Cartridge not installed properly
Need to make sure that is is on there firm and snap in the right way.
Jun 25, 2009 | Canon PIXMA iP1300 Printer
Error 03 turn off printer
please check some cable connector if the theres some disconnections... inside the printer.
Jun 16, 2009 | Epson DFX-9000 Matrix Printer
Waste ink tank / absorber
you need to dismantle the printer by opening the scanner lid, pinging the blue arm out of the white retainer with a screw driver, flip the scanner lid right over onto the desk on the LH side of the printer - it will come off its hinges for this. lay it lid down on the LH side of the printer - be careful not to snap the power and data cable connecting with the base. Next you have to remove the 4 retainer screws in order to remove the plastic cover over the rest of the base. The pad and ink box are at the rear on the right hand side.
Oct 28, 2008 | Brother DCP 115C All-In-One InkJet Printer
HP LaserJet 1000 Printer Logo
44 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
