Question about Dryers
I have a whirlpool dryer the timer quit moving when the dryers running and its not heating up the heating element looks good no burns or anything
  • grandpah22 Jul 31, 2009
    yes both happened at same time voltage is good breakers tripped still doing the same thing
    Brigadier General:
  • 4,088 Answers
Try resetting the dryer breaker pair in the house electrical panel--push OFF and then push ON. Did both problems occur at the same time? If no help from the hint, you need to measure the AC voltage (with a voltmeter) across the two slanted slots in the dryer power socket, which should measure ~220 volts. If near zero volts, one of the breaker pair may be defective.
Posted on Jul 31, 2009
  • drallim Aug 01, 2009
    If the breakers tripped again after resetting them, then there is a probable short to ground within the dryer--likely the heating element. Measure resistance from straight pin of power plug to one, then the other of the slanted pins. Both readings should be infinity ohms--anything near zero is trouble on that side. Disconnect the heating element wiring to see if short clears.
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
We have a dryer that works but does not heat
No heat indicates a burned out heating element.Easily replaced.Cant answer on timer.
Apr 08, 2012 | Whirlpool Dryers
Dryer is not heating
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust. The element gets old and briitle with use and eventually needs replacement. That is what you check first. On gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. A limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers. On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer could be the problem. The timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electrical outlet for proper power to the machine. On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine.
May 30, 2010 | Whirlpool LEN2000PW Dryer
Dryer won't heat
you spent a lot for a timer when you needed to check your heating. check the heating element, the high limit, and the thermofuse
Sep 25, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 18, 2009 | Whirlpool Dryers
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer with no heat
Is the igniter glowing yellow? Look inside the pilot access hole and see if it lights up. If it lights up then goes off, it may be the thermal fuse. Once this blows, it has to be replaced. There are pictures all over the internet on the location of this part.
Good luck.
Apr 16, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer problem
dryer works but does not heat up
Mar 12, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
