Question about Canon Office Equipment & Supplies
Error code e00002751-1304
We are getting an error code e00002751-1304
I believe is a defective toner but need confirmation
    Guru:
  • 389 Answers
You rule;govern, such can be, he is bad mixed or humid, install new, but anymore use this one.
Posted on Sep 12, 2009
What does error code c7403 means
Developing unit M noninstalling error
No density detection signal is output from toner sensor M in developing unit M.
CAUSE - Defective connector cable or poor contact in the connector. Defective toner sensor M. Defective engine PWB.
Apr 11, 2016 | Office Equipment & Supplies
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Como soluciono el error 7000 que me sale en la kyocera
Code 7000
Contents: Toner motor lock error A motor over-current signal is detected
continuously for 5 seconds since the toner motor is activated.
Causes: Lump of toner inside toner container.
Check procedures/corrective measures: Replace the toner container.
Causes: Defective toner replenishment drive system.
Check procedures/corrective measures: Replace the developer unit
Causes: Defective toner motor.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB
Jan 21, 2011 | Kyocera FS-2000D Laser Printer
Can you tell me what service call 7002:0006904 on a Kyocera FS 5030N means? Thank you
7002 is the error code; 0006904 is the printer page count.
Error means-
Toner motor 2 overcurrent detection error (cyan toner)
• The engine controller PWB (A0004)
detected the overcurrent of toner
motor 2.
Possable causes-
1. Lump of toner inside cyan toner container or defectiveness of toner replenishment drive system.
Replace the cyan toner container.
2. Defective toner motor 2.
Replace the toner motor 2.
3. Defective engine controller PWB (A0004).
Replace the engine controller PWB (A0004).
Jan 05, 2011 | Kyocera FS1120D Laser Printer
Please help e0020-00ff black toner supply????? comes and goes
Check for blockage in toner supply ,located at rear of hopper. Also is the toner ok
Jun 26, 2010 | Canon imageRUNNER C6800 Copier
System error [f02-04]
I believe you asked the same question before.... Make sure the waste toner cover / plug is removed and that you shook the cartridge to loosing the toner. You may have recieved a bad or defective toner cartridge...Good Luck
Aug 16, 2009 | Sharp AR-168S Copier
Error 592....
Hello sir; The error code you display, means the toner motor defect, just replace it, will take care your problem.
May 27, 2009 | Ricoh Aficio 1085 Laser Printer
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
Vertical white lines
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
Apr 07, 2009 | HP Color LaserJet 4550 Printer
Kyocera Printer error - Help!
The code is for a defective cyan motor. So its either the cyan toner motor or a lump of toner inside the cyan toner container.
Feb 29, 2008 | Kyocera FS-C5030N Led Printer
37 people viewed this question
old marine
old marine
