How to replace a rubber,between the drum and the door
  • 24 Answers
If you are not an engineer i would advise you to get one to replace the door seal.
Posted on Aug 05, 2009
Replacing door gasket
Most door gaskets are available online, most recommended taking drum out to replace, but task can easily be done by removing rubber from hole in machine (end of a spoon helps) then push drum back through the hole and you will see a large clip on rubber to the drum, unscrew clip and pull out rubber, reverse to replace. Good luck.
Feb 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Won't Spin Drum
The problem could be a list of things . Let's start checking the belt , it coul be that the belt is broken or something is keeping it from doing its job ( a piece of clothing coul be stuck) due to the burned rubber smell you detected. It coul also be the electrical door switch and After checking the three first steps then comes the motor part lets hope is not . Good luck
Nov 20, 2013 | Maytag Centennial Series MEDC300XW
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Thanks
Jun 14, 2010 | GE WSXH208A Front Load Washer
How to change door rubber on miele premier 300, can the front of machine be opened allowing to change the door rubber
I'm assuming you mean the flexible rubber between the door and the drum. Can it be replaced? The short answer is no! However...
I recently repaired a door rubber with a tear that caused the water to flood onto the floor. Here's how:
Yes, you can open the front to get to the door rubber however the rubber seal is glued to both the door and the inner drum lip.
You may have to tilt the machine on it's back to remove three screws from the underside of the front lip. (I forget if you need to take the water pump cover out as well but it wouldn't hurt to do so.) This allows the front panel (including door) to drop down a quarter inch or so and be eased out a little.
This allows *better* access to the drum rubber. To repair a tear - really the only reason you would want to do this - you need glue and some tape.
The door rubber is silicone and will stick with normal 'super glue'. However, bear in mind that these machines can do a wash up to 95C, which is hot enough to soften superglue.
I found a new version of superglue called Repair Extreme by Pattex that copes with temperatures up to 120C. It sets in about 5 minutes.
The glue needs to be flexible. Do not use epoxy resin.
I gave the glue some form by sticking a 10-15cm piece of duct tape - the silver shiny plastic tape plumbers use, readily available from any hardware and most supermarkets - to the *back* of the drum rubber. It's a tight squeeze to get your hands in there but it can be done.
Take the tension off the drum rubber by moving the front panel roughly back in place.
Then squeeze a generous amount of glue along the tear (about 3cm long on the bottom edge; a typical problem) to completely whet the edges to be joined.
Apply a little pressure to the location of the tear for a few minutes to help the glue hold fast. Leave the glue to set for at least half an hour before reassembly.
If you can source a replacement drum rubber the old one can basically be removed by force. A good cleaning and then a suitable glue could stick a new unit in place. However, if this is required, seriously consider buying a new unit. It is difficult to make a good seal that will not leak and may not be worth the effort in the first place.
Feb 03, 2010 | Miele 300 Front Load Washer
The rubber section of my Hotpoint WF640P has gone mouldy
The problem is basically caused by doing too many low temp washes.
The scum you refer to is actually bacteria that is bulding up on the door seal.
To avoid this problem reoccuring, the best thing to do is to have the door seal replaced, and periodically do a high temp wash with powder in, but without clothes..
This is called a maintenance wash, and is recommended by most manufactures
Also, after each wash, clean and dry the door seal, this will help prolong it's life.
Hope this helps answer your question.
Please rate my solution.
thanks.
Dec 23, 2009 | Washing Machines
GE Front Loader rubber boot completely out of shape
You can replace the rubber door seal yourself if you are logically minded and are handy with tools. Isolate the washer from the mains supply. Remove the top fixing screws at the back of the washer. Slide the top of the washer to the rear of the washer and remove. Now you will be able to see the outer drum and the securing band to the drum. This needs loosening and moving clear of the outer drum so you can disconnect the seal from the drum. When you open the door, you will find see that the door seal connects to the washer outer body. You should see a holding catch probably made of plastic. This has to be removed and take care not to break anything. When re fitting the seal,you will find on the front inner edge a small hole, this must be in the 6 o'clock position. Working from the door access, feed the new seal on the outer drum and secure it with the retaining band that you removed earlier, at this stage do not fully tighten as you may need to readjust the seal later on. Now working at the door, feed on the door seal and position the small hole at 6 o'clock. If you find that the seal is twisting, then you will have to readjust the the seal on the inner outer drum. When everything is lined up, tighten the inner securing band then the outer retaining band by the door. Recheck that the small hole on the door inner lip is at 6 o'clock and both the door an outer drum securing bands are tight. This done, check for leaks by part filling the washer and then putting the washer on an emptying cycle. If all is well, then isolate the power to the washer and refit the the top of the washer and secure with the screws you removed earlier. On no account put your hands or tools inside the washer when it is on and connected to the power supply.
I have not yet replaced a door seal on your model of washer, but I have done quite a few and the process is the same. I hope you can follow these instructions and if you come across a snag, think about it and i am sure you will find the solution. You can always get to me at FixYa.
Oct 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
