Question about Alpine Car Audio & Video
I have a Alpine multi disc changer do I need a specific connector as car has 3 cables and unit has 7.
SOURCE:
SOURCE: Sanyo 8 pin din cable
from Sanyo LA,Calif
Posted on May 11, 2008
Eagleeyes
  • 199 Answers
SOURCE: car multi cd changer wont eject
hi
do you have any model numbers on the cd changer?
Posted on Nov 25, 2008
SOURCE: cd multi changer
I understand that there is a 'clear' or 'reset' button on some cd changers that must be pressed after unit is connected in car. The instructions for my model said to use the tip of a pencil.
Posted on Aug 13, 2009
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Posted on Nov 03, 2009
str8gooods
  • 13 Answers
SOURCE: I removed my Mercedes 6 disc cd changer from my
Without power. you may just have to disassemble the unit.
Posted on Mar 08, 2010
How do i install my alpine cd changer to a kenwood mp528 unit
It is unclear which Alpine CD changer you have and what output connections are available from it.
However your Kenwood unit has Aux input terminals at the back. With appropriate cable connectors you should be able to hook the two up. In the Kenwood you will have to select AUX in menu when playing CD changer. Download user manual for Kenwood from this site.
http://www.kenwoodusa.com/Support/Car_Entertainment/
Search using full model number KDC-MP528
Sep 04, 2014 | Kenwood Car Audio & Video
I have a CHA 1214, and it has disc 4 stuck in the changer and I get error 1 on the head unit. it had stuck on track one of each of the first 3 discs so i kept changing to see if it was a disc problem....
Possible, however, that's not the problem. You need to pull the unit out and open the housing. Chances are you have a load error, two discs on one tray, fairly common problem. It is a self repair if your electronics friendly and take your time. Do not use force! once you've pulled the jammed disc out, plug the changer back in while it's still apart and let it cycle, should be fine. If you've got some, use "Dust off" and clean out the chassis. Do not spray on the optical pickup lens! Get a Laser lens cleaning disc that uses fluid, run it thru a couple times and you should be good to go. Hope this helps. If you need further help with this, post a comment. I did 16 years in car audio in my prior life, and can walk you thru it.
Jan 09, 2011 | Alpine CHA-1214 12-Disc CD Changer
I cannot get multi CD changer to play CD's. Single CD in main unit is OK but no track info etc appears on screen. Also cannot eject cd's in myulti changer.
This seems to be a failure of the micro controller of the unit as it fails to identify as well as display the functions.
You will need to check he connecting cord , check the connectors and the inner voltage to the circuits.
Oct 11, 2010 | Bose Wave music system Multi-CD Changer...
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
Manual retrieval of a CD from an Alpine S620 CD Changer
Sorry but no. With the units power lead fused, you can hold the red wire to the + terminal of the battery and the black lead to the chassis of the car and power up and eject. good luck
Jul 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
Which radio for land rover
Usually an Alpine unit.  Try ebay.
Mar 24, 2009 | Alpine CHM-S620 6-Disc CD Changer
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Power cable for A1451
yes if you will open up the unit and look on the circuit board that it connects to it is labeled plain as day what each plug is (b+, gnd..) find that out and thats how ya do it
Apr 15, 2007 | AudioBahn A1451 10-Disc CD/DVD Changer
Car Audio & Video Logo
27 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
