Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Drain problems.
By netdown8 on Jul 31, 2009
Doesn't drain. Drains a few seconds and then stops for a few minutes. Finally gives up and gives me a "come help me" beep.
Best Solution
posted on Jul 31, 2009
Helpful)
localwonder
Rank: Guru  Washers & Dryers  Expert
Rating: 92%, 3130 votes
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
whirlpool ultimate care ii washer LSQ9110PW2
Answer
cold water inlet valve gives a trickle only, even though it is getting full 11.90 volt command... (More)
Answer
I was downloading a software from filehippo but by mistake it was cancelled by me & just ... (More)
Answer
dear sir i want to know how to oprating machine frunt loding
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , IL
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
